Author Topic: 3rd party command definition  (Read 2983 times)
« on: April 14, 2006, 05:04:57 PM »
How would I get lisp to recognize this command that is defined through 3rd party software?
(if (or (= (getvar 'lunits) 3) (= (getvar 'lunits) 4))
  (command "WID_SetDesignArcRadius" "5'")
  (command "WID_SetDesignArcRadius" "5")
If I paste "WID_SetDesignArcRadius" into the command line it is recognized....but in the lisp it is not?
Thanks,
Ron
Serge J. Gianolla
Re: 3rd party command definition
« Reply #1 on: April 14, 2006, 05:28:48 PM »
(WID_SetDesignArcRadius "5'")
« Reply #2 on: April 14, 2006, 05:31:36 PM »
Nice try but....
; error: no function definition: WID_SETDESIGNARCRADIUS
« Reply #3 on: April 14, 2006, 05:42:31 PM »
You will probably be able to run it by:
 (C:WID_SETDESIGNARCRADIUS)
but you won't be able to pass the "5" to it......that's one limitation of lisp commands. If you can find if & where this value gets stored then you may have better luck modifying yourself.
Serge J. Gianolla
« Reply #4 on: April 14, 2006, 05:49:42 PM »
Nice try but....
This error means your function was not loaded.
And as Jeff started mentioning about argument passed to routine, check if you have similar:
(defun c:WID_SETDESIGNARCRADIUS (sVal / ....)
« Last Edit: April 14, 2006, 05:53:33 PM by Serge J. Gianolla »
« Reply #5 on: April 14, 2006, 07:16:31 PM »
Thanks for the ideas guys....I figured it out. I guess the progem is written in visualbasic so....
(command "-vbarun" "WID_Dispatch.SetDesignArcRadius" "5'")
works from lisp :)
FengK
« Reply #6 on: April 15, 2006, 04:01:32 AM »
Ron
How about
(command "VBASTMT" "ThisDrawing.SendCommand \"WID_SetDesignArcRadius\"")
Andrea
« Reply #7 on: April 15, 2006, 03:20:56 PM »
Maybe not a good help...but..
  (setq val1 "5'")
  (setq val1 "5")
(vl-cmdf "WID_SetDesignArcRadius" val1)
;;also you can try this...
(setq val1 (strcat "5" (chr 39)))
;;or this...
(vl-cmdf "WID_SetDesignArcRadius" "!val1")
Keep smile...
