Author Topic: Lisp for Dummies book?  (Read 10429 times)
Andrew H
« on: June 15, 2004, 03:12:12 PM »
Is there a good "Lisp for Dummies" book (or equivalent)? What do you recommend if not a book?
« Reply #1 on: June 15, 2004, 03:14:10 PM »
« Last Edit: February 07, 2007, 07:46:43 AM by CAB »
« Reply #2 on: June 15, 2004, 03:15:49 PM »
Andrew H
« Reply #4 on: June 15, 2004, 03:19:56 PM »
Darn you're quick. Thanks for the links (i've already stared reading). I'll let you know how it goes.
DEVITG
LISP for Dummies
« Reply #5 on: June 15, 2004, 07:38:58 PM »
As I was , and still I'm a LISP DUMMIE , I did  my first with
http://courses.home.att.net/autolisp/
It is really a KINDERGARDEN   LISP course.
« Reply #6 on: June 15, 2004, 09:51:19 PM »
You guys do know that SMadsen has AutoLisp leesons right?!  Ive read the first three chapthers and i was _very_ impressed. Ive read alot on lisp and his lessons are by far the best! (And thats not a plug or anything, im serious!)
SMadsen
« Reply #7 on: June 16, 2004, 07:42:56 AM »
Se7en, thanks for the kind words.
DEVITG
« Reply #8 on: June 16, 2004, 08:34:22 AM »
I agree with you about Stig Madsen's  Lisp course , I browse it last nite, it is amazing.
Nice tip to check intersections with the select by fence, just a little diamond.
Andrew H
« Reply #9 on: June 16, 2004, 10:07:49 AM »
Yes, I have been looking at SMadsen's "Introduction to AutoLisp" and I must say this is the best, well explained, step-by-step lisp tutorial I've ever seen. I've been using AutoCAD for 7+ years and using other people's autolisps for almost as long, so I knew eventually I'd have to learn to write them to put this program (ACAD) to the best use. I have searched the net endlessly for a simple, easy to understand lisp tutorial and I have finally found what I was looking for. Thank you so much S. Madsen for all your help, you'll never know how much you've help me. (I finally get it)
« Reply #10 on: June 16, 2004, 10:28:43 AM »
Quote from: SMadsen
I cant take credit for the truth Stig.
SMadsen
« Reply #11 on: June 16, 2004, 10:47:19 AM »
Thank you very much, Andrew. Only glad to help out if possible.
I'm not sure, but I believe Se7en was referring to a certain 10 lesson series which is a bit more 'indepth' than the three pages I chose to call "Primer".
*gotta make a frame-less site one of these days*
Andrew H
« Reply #12 on: June 16, 2004, 10:57:55 AM »
That's where I'm heading to next (more in-depth studies). I learned a lot from your "Primer". But as I was interrupted several times and need to take a few more notes, I'll be re-reading it to make sure I understand all the concepts before moving on.
I do still want to express my most humble thanks to you (and everyone helping me in this endeavor) for taking the time to write an easy-to-use "Lisp for Dummies" tutorial.
MickD
Re: Lisp for Dummies book?
« Reply #13 on: February 06, 2007, 08:07:54 PM »
Are Stig's courses still available or does nayone know how I could access them? The links above no longer work, thank you.
- John Carmack
- J.R.R. Tolkien
« Reply #14 on: February 06, 2007, 10:17:19 PM »
Stig now has his site attached to TheSwamp
probably  somethingLike/~stig/
... but I don't know about the lessons , where they're gone. I only recall seeing 9 not 10.
