Author Topic: Can anyone tell me why I cant open this dwg in 2009?  (Read 6298 times)
Pad
« on: September 02, 2014, 01:32:22 PM »
Hello,
It was produced with 2014 lt, It will open in 2014, its saved as 2004 I think, but I cant open it.
Autocad freezes when opening.  It doesn't appear to have a large scale list, I'm not sure what else to look for.
Any idea what could be preventing it and how to fix it?
Pads
Rob...
Re: Can anyone tell me why I cant open this dwg in 2009?
« Reply #1 on: September 02, 2014, 01:36:43 PM »
SAVE AS is not the proper way to save a drawing to a previous version. While it does work with some files, it really should be done using EXPORTTOAUTOCAD.
CAD Tech
Matt__W
  • I like my water diluted.
« Reply #2 on: September 02, 2014, 01:43:32 PM »
It's definitely a 2004 DWG.  I haven't tried opening it yet (I only have 2015 MEP).
http://en.wikipedia.org/wiki/.dwg#Version_history
Autodesk Expert Elite
Matt__W
« Reply #3 on: September 02, 2014, 01:46:55 PM »
I ran the AECTOACAD command on your drawing and saved down to 2004.  Try this version.
Rob...
« Reply #4 on: September 02, 2014, 01:57:58 PM »
On a side note, I don't think vanilla AutoCAD recognizes AECTOACAD but I may be wrong.
CAD Tech
Pad
« Reply #5 on: September 02, 2014, 01:58:44 PM »
thanks for the replies.
Ive tried exporttoautocad and the aectoacad version but it still freezes.
looks like it gets to 24% then the freeze happens.
Weird.
Pad
« Reply #6 on: September 02, 2014, 02:00:14 PM »
also tried dxfout from acad 2014.
Pad
« Reply #7 on: September 02, 2014, 02:06:13 PM »
Its a pain.  I need this drawing on site tomorrow using my laptop which only has 2009.
P
Rob...
« Reply #8 on: September 02, 2014, 02:08:08 PM »
How about trying Drawing True View, which is free from AutoDesk, to convert it?
CAD Tech
Pad
« Reply #9 on: September 02, 2014, 02:11:21 PM »
Ive tried that, but thanks for the idea, I also have any dwg dxf converter, it converts it fine, but I cant open it.  I think my next step is to open in 2014 and copy clip everything into a fresh drawing.
P
Matt__W
« Reply #10 on: September 02, 2014, 02:18:38 PM »
Were you able to open the DWG I converted??
Pad
« Reply #11 on: September 02, 2014, 02:28:08 PM »
no, same thing happened.
I'm copying everything out into a fresh drawing, hopefully this will do it.,
Rob...
« Reply #12 on: September 02, 2014, 02:35:12 PM »
Do you have any proxy objects in the 2014 version? If so, you will need to get the object enabler.
CAD Tech
Pad
« Reply #13 on: September 02, 2014, 02:53:47 PM »
Not that I know of.  Copyclip into a fresh drawing doesn't even work..
Matt__W
« Reply #14 on: September 02, 2014, 03:00:59 PM »
Try this one.  I removed the PDF that wasn't found.  Just curious if maybe that's the reason it's hanging up for you.
