Author Topic: ActiveX Speed  (Read 2669 times)
ActiveX Speed
« on: April 20, 2006, 12:19:20 PM »
I just did a test:
      (vla-AddCircle
doc
(vlax-3d-point (trans pt 1 0))
(/ cir_diam 2)
2770 iterations
< Elapsed time: 4.812000 seconds. >
(command ".circle" pt "D" cir_diam)
2770 iterations
< Elapsed time: 70.281000 seconds. >
That's quite the improvement in speed :).
Re: ActiveX Speed
« Reply #1 on: April 20, 2006, 12:36:51 PM »
How about this?
(entmake (list (cons 0 "CIRCLE")
               (cons 10 (list 0.0 0.0 0.0))
               (cons 40 20.0)))
Re: ActiveX Speed
« Reply #2 on: April 20, 2006, 01:39:24 PM »
(defun ent(/)
   (start-timer)
  (repeat 2770
   (cons 40 20.0)
  (end-timer)
;< Elapsed time: 1.032000 seconds. >
(defun ax(/)
  (start-timer)
  (repeat 2770
    (vla-AddCircle
      (vla-get-modelspace
(vla-get-activedocument (vlax-get-acad-object))
      (vlax-3d-point (trans '(0 0 0) 1 0))
      (/ 20 2)
  (end-timer)
;< Elapsed time: 2.219000 seconds. >
(defun cmd(/)
   (start-timer)
  (repeat 2770
    (command ".circle" "0,0,0" "D" "25")
  (end-timer)
;< Elapsed time: 20.953000 seconds. >
Can you feed entmake variables?
Re: ActiveX Speed
« Reply #3 on: April 20, 2006, 01:47:15 PM »
Yup.
Re: ActiveX Speed
« Reply #4 on: April 20, 2006, 01:53:06 PM »
Sure
               (cons 10 (trans pt 1 0)))
               (cons 40 (/ cir_diam 2))))
Re: ActiveX Speed
« Reply #5 on: April 20, 2006, 01:53:48 PM »
