Author Topic: Vlisp ssget equivalent for extended data entities  (Read 2497 times)
csgoh
« on: April 16, 2006, 08:25:49 AM »
(ssget "x" '((0 . "LINE")  (-3 ("Appname1" "Appname2"))))
What is the equivalent in ActiveX/Vlisp?
I wrote the following function and I thought it could also incorporate extended data entity but it returned a vlax-safearray-fill error. I know that using the above to get the entities and convert to a vla-object is much easier. But I am just curious and to further improve my understanding of activex/vlisp safearray, I hope to get some answers from you guys. The following function is the result I have learnt from this forum and is a compilation of functions obtained from here. And I must say, I have improved my programming skills and a big thanks to all of you.
;; wg:SelectObjects
;; USAGE:
;; Arguments
;; Nme  = Selection set name - [STR}
;; Mde  = Select mode [INT] (1)
;;      - Constants:
;;      - acSelectionSetWindow - 0
;;      - acSelectionSetCrossing - 1
;;      - acSelectionSetPrevious - 3
;;      - acSelectionSetLast - 4
;;      - acSelectionAll - 5
;; Pt1  - First window corner [LIST} (2)
;; Pt2  - Next window corner [LIST} (2)
;; whatobjects = Dotted pair list of filtered entities to be selected
;; Returns - [LIST]
;; Returns a list of the objects that match the filter list
;; USAGE :
;; eg. (wg:GEtObjectsOnScreen-list GB:ActivedocumentObj (list '(0 . "INSERT")))
;;           (list '(-4 . "<OR")'(0 . "CIRCLE")
;;                 '(0 . "ARC")'(-4 . "OR>")))
;; Requires
;; wg:NewNameSelectionSet Function
;; wg:SsetFilter Function
;; wg:VariantArrayToList function
(defun wg:SelectObjects-list (Nme Mde Pt1 Pt2 whatobjects /
                                   objects-list
                                   ssObj
                                   FstPnt NxtPnt FltList
                                   filter_what?
  (setq ssObj (wg:NewNameSelectionSet Nme)
        FstPnt (cond (Pt1 (vlax-3d-Point Pt1))(T nil))
        NxtPnt (cond (Pt2 (vlax-3d-Point Pt2))(T nil))
        FltList (cond (whatobjects (wg:SsetFilter whatobjects))(T nil))
  (if Mde
     (if FltList
      (vla-Select ssobj Mde FstPnt NxtPnt (car FltList)(cadr FltList))
      (vla-Select ssobj Mde FstPnt NxtPnt)
     (if FltList
       (setq filter_what? (mapcar 'vlax-variant-value
                        (wg:VariantArrayToList (cadr fltlist))))
       (setq filter_what? (subst "BLOCK" "INSERT"
                 (vl-remove "AND>"
                  (vl-remove "<AND"
                   (vl-remove "OR>"
                    (vl-remove "<OR" filter_what?))))
       (prompt "\nPls select ")(princ (vl-sort filter_what? '<))
       (princ " objects....")
       (vla-SelectOnScreen ssobj (car FltList)(cadr FltList))
      (vla-SelectOnScreen ssobj)
   (setq objects-list '())
   (vlax-for eachobj ssobj
    (setq objects-list(cons eachobj objects-list))
  objects-list
) ; wg:SelectObjects-list
;; wg:SsetFilter
;; Creates a filter for the SelectXXX methods
;; Arguments
;; Flt = Dotted pair list '((0 . "Name"). . .(8 . "LAYER")) - [LIST]
;; Returns
;; List of two arrays '(TypArr DatArr) - [LIST]
;; Requires
;; wg:ListToVariantArray function
 (defun wg:SsetFilter (Flt)
  (mapcar
; this lambda needs 2 lists
    '(lambda (Typ Dat) (wg:ListToVariantArray Typ Dat))
      (list 2 12)
      (list (mapcar 'car Flt)
            (mapcar 'cdr Flt))
 ); wg:SsetFilter
;; converts an array to list
;; Argument
;; Arr = Variant Array [VARIANT]
;; Returns [TYP]
;; - Standard List [LIST]
;; - nil if array is empty
(defun wg:VariantArrayToList ( Arr / TmpVal)
  (setq TmpVal (vlax-variant-value Arr))
  (if (safearray-value Tmpval)
    (vlax-safearray->list Tmpval)
);wg:VariantArrayToList
;; Converts list into variant safearray
;; Argument
;; Lst   = Standard list [LIST]
;; Typ   = Datatype [INT]
;;       - constants
;;       - vlax-vbBoolean
;;       - vlax-vbDecimal *
;;       - vlax-vbDouble
;;       - vlax-vbInteger
;;       - vlax-vbLong
;;       - vlax-vbObject
;;       - vlax-vbSingle
;;       - vlax-vbString
;;       - vlax-vbVariant
;; Return [TYP]
;;       - Array [VARIANT]
;; Cannot be used for dotted pair or nested lists
 (defun wg:ListToVariantArray (Typ Lst)
  (vlax-make-variant (vlax-safearray-fill
   (vlax-make-safearray Typ (cons 0 (1- (length Lst))))
    Lst
); wg:ListToVariantArray
;; USAGE:
;; (wg:NewNameSelectionSet "Name of SS")
;; Returns a vla-object of selection set
;; 26-12-05
(defun wg:NewNameSelectionSet(SelSetName / ssCollection)
  (setq ssColection (vla-get-selectionsets GB:ActivedocumentObj))
  (setq SelSetName (vlax-make-variant SelSetname))
  (if (vl-catch-all-error-p
        (vl-catch-all-apply 'vla-item (list ssColection SelSetName))
      (vla-add ssColection SelSetName)
      (vla-delete (vla-item ssColection SelSetName))
  ) ;_if
); wg:NewNameSelectionSet
(defun c:test()
 (setq GB:ActivedocumentObj (vla-get-Activedocument
                             (vlax-get-acad-object))
       allobects (wg:SelectObjects-List "SS1" 5 nil nil
                  (list '(-4 . "<OR")'(0 . "LINE")'(0 . "INSERT")
                         '(-4 . "<AND")
                           '(0 . "TEXT")'(8 . "1")
                         '(-4 . "AND>")
                        '(-4 . "OR>")))
(defun c:test1()
                   (setq a (list '(0 . "LINE") '(-3 ("test1"))))
Jürg Menzi
  • Oberegg, Switzerland
Re: Vlisp ssget equivalent for extended data entities
« Reply #1 on: April 16, 2006, 08:46:58 AM »
It would be nice to mention the source of this code.
It's injustice to remove the copyright (if there is one), also if you made some minor changes... :-(
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
Fatty
« Reply #2 on: April 16, 2006, 10:29:52 AM »
Happy Easter Jürgen!
Oleg
Jürg Menzi
« Reply #3 on: April 16, 2006, 05:32:18 PM »
Same to you, Oleg... :-)
BTW, glad to have you in this community!
