Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Biscuits on April 21, 2006, 09:21:48 AM
This is part of an old print routine routine that was working great until we got a new printer with new drivers.
I need to replace "LETTER" with "LETTER (8.5 x 11)".
Problem is that the parentheses mess up the routine. Any ideas?
(SETQ PSIZ "LETTER"
PORT "LANDSCAPE"
PSTN "MINE.CTB"
Is this what you want ?
(SETQ PSIZ "LETTER (8.5 x 11)"
PORT "LANDSCAPE"
PSTN "MINE.CTB"
Doesn't work Kerry.
"letter" substitutes the established variable (PSIZ).
"LETTER (8.5 x 11)" is what the new printer driver now requires at the command line (not lisp), but if I put "LETTER (8.5 x 11)" into the routine, the additional parentheses messes up the routine.
Hope I'm making sense.
(DEFUN C:ZPLOT (/ LPGE NOFP OFRM PORT PRTR PSIZ PSTN STDP VNAM)
; DEFUN C:ZPLOT WITH VARIABLES FOR
; LPGE = LAST PAGE TO PLOT
; NOFP = NAME OF PRINTER
; OFRM = OUTPUT FORMAT
; PORT = PLOT ORIENTATION (LANDSCAPE OR
; PORTRAIT)
; PRTR = PRINTER TO USE (BY AREA)
; PSIZ = PAPER SIZE (11X17 OR LETTER)
; PSTN = PLOT STYLE TABLE NAME
; (LOZIER.CTB OR LOZIERII.CTB)
; STDP = STANDARD PLOT
; VNAM = VIEW NAME ( 1, 2, 3,.........20)
(SETVAR "CMDECHO" 0)
(INITGET "E T D")
(SETQ PRTR (GETKWORD (STRCAT "\nPlot to printer in "
"Engineering/meTal/wooD. [E/T/D] "
"<meTal>: "
) ; REQUEST PRINTER TO USE (PRTR)
(COND
((EQUAL PRTR "E")
(SETQ NOFP "MODFT2_HP5SI")
((EQUAL PRTR "D")
(SETQ NOFP "MODFT1_HP4V")
((OR
(NULL PRTR)
(EQUAL PRTR "T")
(SETQ NOFP "MODFT1_HP5SI")
(INITGET "V H B")
(PRINC "\nChoose format for output: ")
(SETQ
OFRM (GETKWORD (STRCAT "\naVertical/aHorizontal/Bsize "
"[V/H/B] <Bsize>: "
) ; REQUEST OUTPUT FORMAT (OFRM)
(COND ; BEGIN OUTPUT FORMAT TEST CONDITIONS
((EQUAL OFRM "V") ; OFRM = AVERTICAL?
(SETQ PSIZ "LETTER)"
PORT "PORTRAIT"
PSTN "MINEII.CTB"
((EQUAL OFRM "H") ; OFRM = AHORIZONTAL?
PORT "LANDSCAPE"
PSTN "MINEII.CTB"
((OR ; OFRM = NULL OR BSIZE?
(NULL OFRM)
(EQUAL OFRM "B")
(SETQ PSIZ "11X17"
PORT "LANDSCAPE"
PSTN "WOOD.CTB"
) ; END OUTPUT FORMAT TEST CONDITIONS
(INITGET (+ 2 4))
(SETQ VNAM (GETINT "\nEnter first View Name to plot <1>: "))
(IF (NULL VNAM)
(SETQ VNAM 1)
(INITGET (+ 2 4))
(SETQ LPGE (GETINT "\nEnter last View Name to plot <1>: "))
(IF (NULL LPGE)
(SETQ LPGE 1)
(WHILE ; BEGIN PLOT WHILE
(<= VNAM LPGE)
(COMMAND "-PLOT" "YES" "MODEL" NOFP PSIZ "INCHES"
PORT "NO" "VIEW" VNAM "FIT" "CENTER"
"YES" PSTN "YES" "NO" "NO" "NO"
"YES"
(SETQ VNAM (1+ VNAM))
) ; END PLOT WHILE
(SETVAR "CMDECHO" 1)
(PRINC "\nPlotting Complete. ")
(PRINC)
Can you do a plot completely at the command line and post back the command line text .. please
It may not be the parentheses but the space after letter.
This is/maybe the problem
(SETQ PSIZ "LETTER) "
You don't edit in the VLIDE, do you ;=)
I just found that Kerry. That was a result of poor editing. That wasn't the original cause the problem just a new one I've corrected. Original problem still exists.
I thank all of you for your help. I'm still stuck
It's way past my bedtime, and I need my beauty sleep ... so if you do post as noted in Reply #3 I'm sure someone will attempt to help.
Here ya go
-plot
yes
model
MODFT1_HP5SI.PC3
LETTER (8.5" X 11")
inches
landscape
no
view
1
fit
0,0
yes
lozierii.ctb
yes
no
no
no
yes
try this in your code
"LETTER (8.5\" X 11\")"
THAT DID IT
Kerry you rule
Thanks a bunch
Now get some sleep
