Author Topic: Severe Error  (Read 2154 times)
Fabricio28
Severe Error
« on: April 03, 2014, 08:18:09 AM »
Hi guys,
I am getting the following error message when plotting:
AutoCAD Severe Error - File not found.
I'm using autocad 2012
Does anyone have any ideas what might cause this?
Thank you
Rob...
Re: Severe Error
« Reply #1 on: April 03, 2014, 08:23:59 AM »
Captain Obvious: A missing file.
Me: Did you try rebooting?
CAD Tech
Fabricio28
Re: Severe Error
« Reply #2 on: April 03, 2014, 08:26:13 AM »
Hi Rob Draw,
you mean options > Profile > Reset?
After doing that showed that messagem.  :-D
Rob...
Re: Severe Error
« Reply #3 on: April 03, 2014, 08:32:44 AM »
No, reboot your machine.
CAD Tech
Fabricio28
Re: Severe Error
« Reply #4 on: April 03, 2014, 08:41:07 AM »
I've already reset my computer.
That message is showed since I reset the autocad 1 week ago.
Rob...
Re: Severe Error
« Reply #5 on: April 03, 2014, 08:44:03 AM »
Why did you reset?
Do you still have the old profile that did not produce that error?
It sounds like AutoCAD is looking for something that it cannot find. Does it tell you the name of the file? Find that file and make sure that the appropriate search path is pointing to it.
CAD Tech
Fabricio28
Re: Severe Error
« Reply #6 on: April 03, 2014, 08:52:18 AM »
I reseted my autocad because the Ribbon had gone.
The Ribbon had gone because I download a app in exchange autodesk.
The error isn't show the name of the file. I don't know what to do
Rob...
Re: Severe Error
« Reply #7 on: April 03, 2014, 08:58:44 AM »
Without more information, I think you have a serious problem and it's time for drastic measures.
Try to run a repair on AutoCAD.
If that does not work, a reinstall may be in order. Make sure to follow the direction from Autodesk for the reinstall if you have to do that. There is a procedure for fully uninstalling AutoCAD that is necessary for a reinstall to be clean.
CAD Tech
Fabricio28
Re: Severe Error
« Reply #8 on: April 03, 2014, 09:21:12 AM »
Thank you for the assistence RobDraw,
I'll check it out and I let you know if worked.
Matt__W
  • I like my water diluted.
Re: Severe Error
« Reply #9 on: April 03, 2014, 09:44:55 AM »
Autodesk Expert Elite
Re: Severe Error
« Reply #10 on: April 03, 2014, 09:49:29 AM »
looks like you lost your plot styles
Fabricio28
Re: Severe Error
« Reply #11 on: April 03, 2014, 10:06:24 AM »
Guys,
I can't set my plot stamp.
I think the problem is the plot stamp. How Can I fix it?
I did everything you said in this topic and didn't work yet.
 :cry:
« Last Edit: April 03, 2014, 10:11:18 AM by FABRICIO28 »
ChrisCarlson
Re: Severe Error
« Reply #12 on: April 03, 2014, 10:12:15 AM »
Can you locate the plot stamp on your computer?
Fabricio28
Re: Severe Error
« Reply #13 on: April 03, 2014, 10:18:01 AM »
Command: (findfile "inches.pss")
"C:\\Users\\Owner\\appdata\\roaming\\autodesk\\autocad 2012 -
english\\r18.2\\enu\\support\\inches.pss"
What am I suppose to do with inches.pss file?
Can I delete the file and restart the autocad?
I've created many stamp before I reset the autocad.
« Last Edit: April 03, 2014, 10:24:47 AM by FABRICIO28 »
Fabricio28
Re: Severe Error
« Reply #14 on: April 03, 2014, 10:42:03 AM »
Problem solved guys!!!
I've unmade everything I did before the problem.
I uninstall some app from autocad and restarted.
Thank you all of you guys for the support.
Regards
« Last Edit: April 03, 2014, 11:22:57 AM by FABRICIO28 »
