To answer the original question, we use several different colors, many with the same lineweight, mostly because we can then see it on the screen and know what we are looking at.
Red = .5
Yellow = .7
Green = .35
Blue, Cyan, White = .25
Magenta = .18
Several other colors, mostly using .25, and a couple that use 1.
I looked at switching to STB a while back. I couldnt find a reason to make the switch. I found more cons than pros. Our dim text needing to be heavier than our dim lines was one of them. If they are all on the same layer, and the lineweight is controlled by the layer, you cant do it. I think there is a poll I posted on it somewhere around here. Nobody was heavily in favor of one way or the other.
