Author Topic: exporting to PDF in acad 2010  (Read 10398 times)
chrisdarmanin
« on: April 23, 2009, 06:29:03 AM »
i got this...  :-( :-(
can anyone help?
using acad 2010
Job: - Canceled
Job ID: 1
Sheet set name:
Date and time started: 23/04/2009 12:30:09
Date and time completed: 23/04/2009 12:30:14
UserID: Cdarm
Profile ID:
Total sheets: 1
Sheets plotted: 1
Number of errors: 1
Number of warnings: 0
 Sheet: MIA GROUND FLOOR-Model - Plotted with Error(s)
File: G:\Medairco\Technical Dept\Contracts\2008\C2091 - MIA\Drawings\CHRIS DRAWINGS\MIA As Fitted Drawings\MIA GROUND FLOOR.dwg
Category name:
Page setup:
Device name: DWG To PDF.pc3 - plotted to file
Plot file path: C:\Documents and Settings\Cdarm\Desktop\MIA GROUND FLOOR.pdf
Paper size: ISO full bleed A1 (594.00 x 841.00 MM)
ERROR: Internal Error: Null Pointer
Kate M
Re: exporting to PDF in acad 2010
« Reply #1 on: April 23, 2009, 01:22:50 PM »
Are you using the DWG to PDF.pc3 that came with AutoCAD 2010, or did you migrate the old one?
David Hall
  • Automatic Duh Generator
« Reply #2 on: April 23, 2009, 01:34:02 PM »
Kate, is the new one broken?  I ask b/c the 08 version was broken, and the work around was to bring the 07 version forward
Matt__W
  • I like my water diluted.
« Reply #3 on: April 23, 2009, 01:40:36 PM »
Considering Autodesk's track record when it comes to actually fixing stuff that should be working to begin with....
Quote from: Autodesk Upper-Management
Hey! I've got an idea.  Instead of using our time to fix the bugs, let's totally revamp the way our software looks.  Hmmm... but how?  Oh, I know!!  Let's make it look like Microsoft Office!  Let's just "borrow" their ideas and call it our own!
Ummmm... no comment.   :roll: :wink:
Autodesk Expert Elite
Kate M
« Reply #4 on: April 23, 2009, 02:16:55 PM »
No, using an old PC3 is what causes the problem.
Krushert
  • FREE BEER Tomorrow!!
« Reply #5 on: April 23, 2009, 02:33:23 PM »
UH OHHH  :oops: :cry:
M-dub
« Reply #6 on: April 23, 2009, 02:34:29 PM »
What?  Is it really THAT troublesome to create new ones?
Krushert
« Reply #7 on: April 23, 2009, 03:08:19 PM »
No Cotton but it felt good in saying that and you like it.
M-dub
« Reply #8 on: April 23, 2009, 03:12:24 PM »
Uhhh.... What?   :?
Maverick®
« Reply #9 on: April 23, 2009, 03:14:29 PM »
Antithenes!?!?!  Where ya been buddy!
chrisdarmanin
« Reply #10 on: April 23, 2009, 05:14:19 PM »
back to the topic...
i clicked on export from the big 'A' in the corner, i tried it from the ribbon and also used the dwg to pdf plotter but nothing worked. oh and even from the publish command. then i did like always and used cutepdfwriter... (i like that little piece of software :) )
KewlToyZ
« Reply #11 on: April 23, 2009, 05:26:26 PM »
I still use Acroplot, makes a small file size with great detail and extremely high rate of compatability.
chrisdarmanin
« Reply #12 on: April 23, 2009, 05:36:48 PM »
what i liked is that i cam batch print to pdf with the built in pdf writer. with other software i have to print one by one.. (if its not set up as the default printer in the page setup)
Kate M
« Reply #13 on: April 23, 2009, 05:40:13 PM »
Right the question is WHICH dwg-to-pdf plotter you're using. (The method of plotting/exporting doesn't matter if the PC3 file is messed up.) If you migrated the PC3 from an earlier version, delete it and use the one that came with 2010.
chrisdarmanin
« Reply #14 on: April 24, 2009, 01:17:04 AM »
i only got one dwg to pdf (see attached image) and that doesn't work   :-(
any ideas what to do?
