First off, we use LT
My problem is page numbering. We often have 50 or more pages in a set of dwgs. Our numbering scheme is job #, then Page number, then description on the dwg, then Rev #. An example would be -
3822 P008 AHU2 Controls - Rev 1.0.0.dwgThe problem with this is if I want to add a page directly after page 10. I then have to renumber every page after page 10!
I have come up with a utility to rename the files in sequence, this takes a matter of Seconds. But, within the dwgs, I have to open EVERY PAGE and edit the sheet number of the dwg. This can be quite time consuming on large jobs.
Do any of you have an idea how I can do this with a script / macro?
I'm guessing that I would need to be able to pull the page number out of the filename.
This can probably be done pretty easy with Lisps, but again, I am stuck with LT so I am limited to macros.
Thanks in advance,
craigr
