Author Topic: acedRegenLayers  (Read 3466 times)
It's Alive!
  • Retired
  • AKA Daniel
acedRegenLayers
« on: December 29, 2007, 10:09:40 PM »
For anyone following this thread here , and thanks to MJG we have a new function to play with :lol:
    //2007+
    [System.Security.SuppressUnmanagedCodeSecurity]
    [DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl,
    EntryPoint = "?acedRegenLayers@@YGXABV?$AcArray@VAcDbObjectId@@V?$AcArrayMemCopyReallocator@VAcDbObjectId@@@@@@H@Z")]
    private static extern void acedRegenLayers(IntPtr pointer, int num);
    public static void RegenLayers(ObjectIdCollection objectids,int num)
      acedRegenLayers(objectids.UnmanagedObject, num);
    [CommandMethod("doit")]
    static public void toit()
      Editor ed = acadApp.DocumentManager.MdiActiveDocument.Editor;
      try
        ObjectIdCollection objectIds = new ObjectIdCollection();
        Database db = acadApp.DocumentManager.MdiActiveDocument.Database;
          LayerTable table = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
          foreach (ObjectId id in table)
            objectIds.Add(id);
        RegenLayers(objectIds, 0);
      catch (System.Exception ex)
        ed.WriteMessage(ex.Message);
SomeCallMeDave
Re: acedRegenLayers
« Reply #1 on: December 30, 2007, 10:53:51 AM »
Daniel,
Very cool.  Thanks for sharing.
The new function works with some of my routines but I have one that I can't get it work with.
        [CommandMethod("layoutfreeze")]
        static public void FreezeLayerInAllOtherViewPorts()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            ObjectIdCollection layList = new ObjectIdCollection();
            ObjectIdCollection vpList = new ObjectIdCollection();
            PromptEntityOptions opts = new PromptEntityOptions("\nSelect Object whose layer will be frozen in all Other Viewports: ");
            opts.AllowNone = true;
            opts.AllowObjectOnLockedLayer = true;
            //Select the object on-screen
            PromptEntityResult res = ed.GetEntity(opts);
            if (res.Status == PromptStatus.OK)
                ObjectId ObjID = res.ObjectId;
                ObjectId currVPortID = ed.CurrentViewportObjectId;
                try
                    using (Transaction trans = db.TransactionManager.StartTransaction())
                        Entity ent = (Entity)trans.GetObject(ObjID, OpenMode.ForRead, false);
                        Viewport vpEnt = (Viewport)trans.GetObject(currVPortID, OpenMode.ForWrite);
                        ViewportTable vpTbl = (ViewportTable)trans.GetObject(db.ViewportTableId, OpenMode.ForRead);
                        ObjectId layerId = ent.LayerId;
                        layList.Add(layerId);
                        ObjectId layoutDictID = db.LayoutDictionaryId;
                        DBDictionary layoutDict = (DBDictionary)trans.GetObject(layoutDictID, OpenMode.ForRead);
                        foreach(DBDictionaryEntry LayoutDictEntry  in layoutDict)
                            Layout testLayout = (Layout)trans.GetObject(LayoutDictEntry.Value, OpenMode.ForWrite);
                            ObjectIdCollection LayoutVPs = testLayout.GetViewports();
                            foreach (ObjectId testVpEntID in LayoutVPs)
                                    Viewport testVpEnt = (Viewport)trans.GetObject(testVpEntID, OpenMode.ForWrite);
                                    testVpEnt.FreezeLayersInViewport(layList.GetEnumerator());
                                //test it here
                                  //  RegenLayers(layList, 0);
                        //thaw the layer in the current viewport
                        vpEnt.ThawLayersInViewport(layList.GetEnumerator());
                        trans.Commit();
                    }//using
                    //Test the new function here
                }//end try
                    ed.WriteMessage("\nError Freezing Layers: " + ex.Message);
            }// if
        }//FreezeLayerInAllOtherViewPorts
This little function freezes the layers correctly, but the I still must close and re-open the drawing to make the changes apparent.
(The  code currently freezes the layer in the layout itsself (paperspace), which is not exactly the intent.  I will tackle that next)
I have tried the RegenLayers in several places both inside and outside the transaction but still no glory.
Any ideas?
Thanks again for sharing.
It's Alive!
  • Retired
  • AKA Daniel
Re: acedRegenLayers
« Reply #2 on: December 30, 2007, 01:36:07 PM »
please give this a shot
      //added by Dan
      int oldsetting = Convert.ToInt32(AcadApp.GetSystemVariable("LAYOUTREGENCTL"));
      AcadApp.SetSystemVariable("LAYOUTREGENCTL", (object)0);
        try
            foreach (DBDictionaryEntry LayoutDictEntry in layoutDict)
                testVpEnt.UpdateDisplay();//added by Dan
            trans.Commit();
          }//using
        }//end try
        finally
          AcadApp.SetSystemVariable("LAYOUTREGENCTL", (object)oldsetting);
      }// if
« Last Edit: December 30, 2007, 09:33:53 PM by Daniel »
It's Alive!
  • Retired
  • AKA Daniel
Re: acedRegenLayers
« Reply #3 on: December 30, 2007, 10:51:15 PM »
Sorry SCMD, it seems that this new function does not update cached viewports as I first thought  :oops:
SomeCallMeDave
Re: acedRegenLayers
« Reply #4 on: December 30, 2007, 11:11:45 PM »
Dan,
No need to apologize to me, mate :)   I appreciate all your efforts and your willingness to share your findings.
I had followed along in the other thread and was able to get the desired results using the LAYOUTREGENCTL sysvar but was hopeful that the new RegenLayers command would update the viewports.
So what does it do?  Have you found any impact of changing the second argument?
Thanks again,
Dave
