This is my first post since this is the first time I haven't been able to find answers by simply reading other posts.
Now i feel like i belong
Anyways...
I am trying to create a DB for a post fence (or porch fence). In the attached dwg for instance, I want to stretch the fence from A to B.
When I do this, however, I would like the dimensions C and D be equal. The other constraint that I have been asked to attempt to acheive is that the insertion point be the lower left corner of the fence. I think this block would be simple if I could make the insertion point the middle of the fence because I could just set the distance parameter base type to midpoint rather than endpoint.
But I diverge...I realize that C does not equal D because the array action divides the distance by the array offset and rounds down. To avoid this, I was wondering if there was a way to center the initial fence post and then array in both directions. I have tried using a move action with a multiplier of 0.5 and at one point I even had two arrays and a flip action going on, but I abandoned that all together.
Any help would be much appreciated. Thanks in advance.
