Author Topic: Help List  (Read 5830 times)
velasquez
Help List
« on: July 18, 2014, 03:34:03 PM »
I need help for a problem with lists:
I have:
list1: ->
(setq list1 (list '("1" "testA") '("2" "testB") '("3" "testC")))and
list2: ->
(setq list2 (list '("testA" "nononno") '("testB" "vcvcvcv") '("testC" "nmnmnmn") '("nonono" "xccxcxc") '("xxxxxx" "jhjhjhjj")))I need to get list3 ->
'(("1" "teste
A" "aaaaaa") ("2" "testB" "vcvcvcv") ("3" "testC" "nmnmnmn") ("" "nonono" "xccxcxc") ("" "xxxxxx" "jhjhjhjj"))
Can anyone help me?
Re: Help List
« Reply #1 on: July 18, 2014, 04:05:42 PM »
Quick one:
  1. (defun foo ( l1 l2 )
  2.     (setq l1 (mapcar 'reverse l1))
  3.     (mapcar '(lambda ( x / a ) (if (setq a (assoc (car x) l1)) (reverse (cons (cadr x) a)) (cons "" x))) l2)
  4. )
  1. _$ (foo list1 list2)
  2. (("1" "testA" "nononno") ("2" "testB" "vcvcvcv") ("3" "testC" "nmnmnmn") ("" "nonono" "xccxcxc") ("" "xxxxxx" "jhjhjhjj"))
Actually, this is slightly shorter:
  3.     (mapcar '(lambda ( x / a ) (if (setq a (assoc (car x) l1)) (cons (cadr a) x) (cons "" x))) l2)
  4. )
« Last Edit: July 18, 2014, 04:10:37 PM by Lee Mac »
velasquez
Re: Help List
« Reply #2 on: July 18, 2014, 04:36:27 PM »
Thank you Lee
Your help was very important again.
Re: Help List
« Reply #3 on: July 19, 2014, 05:28:48 AM »
You're welcome velasquez  :-)
Re: Help List
« Reply #4 on: July 19, 2014, 05:32:43 AM »
Another, recursive variation (slow):
  1. (defun foo ( a b )
  2.     (if b (cons (bar (car b) a) (foo a (cdr b))))
  3. )
  4. (defun bar ( x l )
  5.     (cond
  6.         (   (null l) (cons "" x))
  7.         (   (= (cadar l) (car x)) (cons (caar l) x))
  8.         (   (bar x (cdr l)))
  9.     )
  10. )
David Bethel
Re: Help List
« Reply #5 on: July 19, 2014, 06:56:32 AM »
or a little simpler way would:
  1. (setq list3 nil)
  2. (foreach a list1
  3.   (setq list3 (cons (list (car a)
  4.                           (cadr a)
  5.                           (cadr (assoc (cadr a) list2))) list3)))
  6. (setq list3 (reverse list3))
  7.
No error checking though which I would recommend  -David
R12 Dos - A2K
Re: Help List
« Reply #6 on: July 19, 2014, 07:56:55 AM »
  1. (setq list3 nil)
  2. (foreach a list1
  4.                           (cadr a)
  7.
What about these items David:
  1. ("" "nonono" "xccxcxc") ("" "xxxxxx" "jhjhjhjj")
:wink:
David Bethel
Re: Help List
« Reply #7 on: July 19, 2014, 10:44:57 AM »
:wink:
Like I said  it needs error checking.  I don't believe there would be any correct answer to your scenario.  My $0.02  -David
R12 Dos - A2K
Re: Help List
« Reply #8 on: July 19, 2014, 12:25:37 PM »
:wink:
I'm just going by the result requested by the OP.
irneb
Re: Help List
« Reply #9 on: July 19, 2014, 03:55:44 PM »
Just a question: Are the 2 lists always in the same order? If so a slightly faster version:
  1. (defun combine (L1 L2 / L3)
  2.   (setq L3 L2)
  3.   (append (mapcar '(lambda (a b) (setq L3 (cdr L3)) (cons (car a) b))) L1 L2)
  4.           (mapcar '(lambda (c) (cons "" c)) L3)))
Else you'll need the assoc to extract the correct item from either L1 or L2 (as the others' are doing).
BTW, is the 2nd list always longer (or same length) as the first or could the 1st list be longer? If so how should the result then look?
« Last Edit: July 19, 2014, 03:59:41 PM by irneb »
velasquez
Re: Help List
« Reply #10 on: July 25, 2014, 07:52:14 PM »
Hi Lee,
I modified your function foo and got the list3 as follows:
(defun LM:foo+ (l1 l2)
  (mapcar '(lambda (x / a)
               (subst (cadr a) (car x) x)
               (subst "" (car x) x)
             ) ;_ fim de if
           ) ;_ fim de lambda
          l2
  ) ;_ fim de mapcar
) ;_ fim de defun
(setq list1 '(("1" "SG_1_TBLUTOP_D90_L2000") ("2" "SG_3_CP90FB-BLUTOP10PECB_D90") ("3" "SG_1_CC90B-BLUTOPPECB_D90")))
(setq list2 '(("SG_1_CC90B-BLUTOPPECB_D90" "CC90B-BLUTOPPECB;Curva 90° com bolsas JE - Sistema Blutop;90;0;0;0") ("SG_3_CP90FB-BLUTOP10PECB_D90" "CP90FB-BLUTOP10/16PECB;Curva 90° com pé, bolsa e flange JE - Sistema Blutop;80;80;10;0") ("SG_1_TBLUTOP_D90_L2000" "TBLUTOP;Tubo ponta e bolsa JE - Sistema Blutop;90;0;0;2000") ("SG_1_KB-BLUTOPPECB_D90" "KB-BLUTOPPECB;Cap JE - Sistema Blutop;90;0;0;0") ("SG_1_KB-BLUTOPTIPECB_D160" "KB-BLUTOPTIPECB;Cap JTI - Sistema Blutop;160;0;0;0")))
I got the list3 with this order:
_$ (setq list3 (LM:FOO+ list1 list2))
(("3" "CC90B-BLUTOPPECB;Curva 90° com bolsas JE - Sistema Blutop;90;0;0;0") ("2" "CP90FB-BLUTOP10/16PECB;Curva 90° com pé, bolsa e flange JE - Sistema Blutop;80;80;10;0") ("1" "TBLUTOP;Tubo ponta e bolsa JE - Sistema Blutop;90;0;0;2000") ("" "KB-BLUTOPPECB;Cap JE - Sistema Blutop;90;0;0;0") ("" "KB-BLUTOPTIPECB;Cap JTI - Sistema Blutop;160;0;0;0"))
_$
You can help me sort the list as list4:?
'(("1" "TBLUTOP;Tubo ponta e bolsa JE - Sistema Blutop;90;0;0;2000")
Thanks for the time and the help of all.
Re: Help List
« Reply #11 on: July 25, 2014, 08:00:07 PM »
Quick one:
  1. (setq l
  2.    '(
  3.         ("3" "CC90B-BLUTOPPECB;Curva 90° com bolsas JE - Sistema Blutop;90;0;0;0")
  4.         ("2" "CP90FB-BLUTOP10/16PECB;Curva 90° com pé, bolsa e flange JE - Sistema Blutop;80;80;10;0")
  5.         ("1" "TBLUTOP;Tubo ponta e bolsa JE - Sistema Blutop;90;0;0;2000")
  6.         ("" "KB-BLUTOPPECB;Cap JE - Sistema Blutop;90;0;0;0")
  7.         ("" "KB-BLUTOPTIPECB;Cap JTI - Sistema Blutop;160;0;0;0")
  8.     )
  9. )
  10.
  11. (vl-sort l '(lambda ( a b ) (if (and (/= "" (car a)) (/= "" (car b))) (< (atoi (car a)) (atoi (car b))))))
velasquez
Re: Help List
« Reply #12 on: July 26, 2014, 06:09:26 AM »
Quick one:
  1. (setq l
  2.    '(
  8.     )
  9. )
  10.
Perfect Lee.
velasquez
Re: Help List
« Reply #13 on: July 28, 2014, 09:22:57 AM »
I'm trying to better understand the mapcar and lambda functions.
I got a result with foreach but I can not say with mapcar.
;;;MyList -> (<Entity name: 7ffffc08530> <Entity name: 7ffffc05960> <Entity name: 7ffffc05440> ...)
(foreach JoyItem MyList
  (if (setq JoyTemp (dxf 1000 (JoyGetXdata (vlax-ename->vla-object JoyItem) "DuctilCAD_2D")))
    (setq JoyData (cons (list (dxf 2 (entget JoyItem)) JoyTemp) JoyData))
  ) ;_ fim de if
) ;_ fim de foreach
;;;returned list -> '(("SG_1_TNATJGS_D80_#D80" "TNATJGS;Tê com bolsas e junta elástica JGS - Linha Natural;80;80;0;0")
My question in this case is better to work with foreach?
I need to learn more about mapcar.
irneb
Re: Help List
« Reply #14 on: July 28, 2014, 10:18:38 AM »
