Author Topic: (MicroStation) Scale of inserted cells  (Read 2877 times)
PHX cadie
« on: May 03, 2010, 11:35:07 PM »
What dictates the scale when inserting a cell?
I have a existing dgn, no idea of the workspace or any of the setup, just when I insert a cell from our "General" file they need to scaled down .01 each time. The border has not been scaled down, it measures 2'-10" x 1'-10" (ANSI D), yet when I copy/paste the same cell from another dgn the cell is ok. This general file has been used several times before w/o scaling the cells down.
Thx's
Acad 2013 and XM
Back when High Tech meant you had an adjustable triangle
Re: Scale of inserted cells
« Reply #1 on: May 04, 2010, 10:43:42 AM »
does this help?  http://docs.bentley.com/en/MicroStation/ustnhelp602.html
I think the setting in question is:
True Scale If on, cells that were created in a model with different units from those of the active model are scaled to adjust them to the units of the active model.
PHX cadie
« Reply #2 on: May 04, 2010, 10:35:08 PM »
I'll keep an eye open on that one!
As always I "Thank You"!
Acad 2013 and XM
