Author Topic: Leader Text  (Read 3021 times)
Leader Text
« on: March 26, 2010, 07:26:50 AM »
How can one tell, using Visual LISP, if Text is associated with a leader?
Thanks in advance,
Lee
Joe Burke
Re: Leader Text
« Reply #1 on: March 26, 2010, 07:59:51 AM »
Lee,
This seem too simple. Check the Annotation property of the leader object. If it returns an mtext object...
Re: Leader Text
« Reply #2 on: March 26, 2010, 08:06:21 AM »
Lee,
Sorry Joe, I meant if you don't have the Leader Object, but just the Text/MText object - can you tell if they are connected?
I would normally check for the presence of the reactor in the DXF table, but I see no immediate way to accomplish this in VL
« Last Edit: March 26, 2010, 08:11:28 AM by Lee Mac »
Re: Leader Text
« Reply #3 on: March 26, 2010, 09:30:22 AM »
I see no way but to search through all reactors. :?
Re: Leader Text
« Reply #4 on: March 26, 2010, 09:34:19 AM »
Oh, I thought there might be an easier way that I was missing  :-(
Thanks anyway guys. :-)
Crank
Re: Leader Text
« Reply #5 on: March 26, 2010, 12:01:38 PM »
Perhaps:
  • First make a selectionset of all leaders
  • Now make a list of the 340 dxf-codes (= pointers to the mtext)
  • If the entityname of the text is a member of the list then it's associated with a leader
Re: Leader Text
« Reply #6 on: March 26, 2010, 12:09:29 PM »
Nice idea Crank, thanks :-)
But I really need to do this with VL, as I'd be using it through ObjectDBX. But, on the topic of testing the text for a leader using dxf, I normally use something like this:
(defun isLeaderText (ent)
  (and (assoc 102   (entget ent))
       (setq own    (cdr (assoc 330 (entget ent))))
       (eq "LEADER" (cdr (assoc 0 (entget own))))))
Not sure if that's a good way to do it though  :|
Re: Leader Text
« Reply #7 on: March 26, 2010, 01:08:07 PM »
You might be able to still do it that way with ODBX.
Re: Leader Text
« Reply #8 on: March 26, 2010, 01:11:06 PM »
I'll give it a try :-)
I know that entmod isn't available, but entget might be  :-)
alanjt
  • Standby for witty remark...
Re: Leader Text
« Reply #9 on: March 26, 2010, 02:35:10 PM »
In early '08, I wrote a routine that would copy (with option to delete) text objects with the QLeader command and change to the current layer. I used the same method to find and delete the attached leader. It did have a flaw that if the MText object had an associated leader, yet already deleted, an executed entdel on an already deleted leader would recreate it. I never followed through with figuring it out since we switched to Multileaders shortly after and I haven't used it since.
Dropbox
Re: Leader Text
« Reply #10 on: March 26, 2010, 02:43:20 PM »
Thanks Alan
Re: Leader Text
« Reply #11 on: March 26, 2010, 03:44:54 PM »
Just FYI... you can see if an entity is deleted a couple of ways.  If ' entget ' returns nil, then it has been deleted.  You can also use ' vlax-erased-p ' on an ename or vla-object.
alanjt
Re: Leader Text
« Reply #12 on: March 26, 2010, 08:13:29 PM »
Ahh, good to know. Thanks Tim. :)
Dropbox
