Author Topic: VBScripting my way to The Registry  (Read 6514 times)
ML
« on: May 22, 2007, 05:16:00 PM »
OK, I am new to VBScripting and (trying) to write to the registry so please be gentle.
I have some code written that goes like this:
  Dim WshShell
 Dim KeyName, ValueName, ValueData As String
 Set WshShell = WScript.CreateObject("WScript.Shell")
  KeyName = "HKEY_USERS\S-1-5-21-1749436377-938699083-1307212239-11542\Software\Autodesk\AutoCAD\R16.2\ACAD-4008:409\Profiles\Test\General"
  ValueName = "SheetSetTemplatePath"
  ValueData = "I:\Path\Test"
    WshShell.RegWrite KeyName & ValueName & ValueData"
    WshShell = Nothing
I am sure there are a few things wrong in the code as it is erroring out on me.
I am a bit suprised, I am not sure why it is erroring out when creating the WScript.Shell Object but that is where it seems to be.
If someone could help steer me in the right direction, I would appreciate it.
Also, I was wondering if it is possible to access The WScript.Shell Object from within AutoCAD VBA as well?
Thank you,
Jeff_M
  • C3D user & customizer
Re: VBScripting my way to The Registry
« Reply #1 on: May 22, 2007, 06:10:34 PM »
If this helps, this works in VBA:
Sub testme()
Dim scrpt As New WshShell
Dim DataVal As String
Dim regKey As String
regKey = "HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.1\ACAD-6000:409\Profiles\Civil3D\General\SheetSetTemplatePath"
DataVal = scrpt.RegRead(regKey)
scrpt.RegWrite regKey, DataVal & "\subFolder"
Debug.Print scrpt.RegRead(regKey)
scrpt.RegWrite regKey, DataVal ''return it to it's origianl state
ML
« Reply #2 on: May 23, 2007, 10:06:47 AM »
Jeff
It doesn't seem to work, I am getting a user defined type not defined.
Are you sure there is an object in VBA called New WshShell?
Jeff_M
« Reply #3 on: May 23, 2007, 04:24:12 PM »
Well, you must add a reference to WindowsScriptingHost and then it will work. Sorry for not mentioning that part.....
ML
« Reply #4 on: May 24, 2007, 12:21:53 AM »
So are you saying that the reference I set should look like this:?
Set scrpt = CreateObject("New WshShell")
Dnereb
« Reply #5 on: May 24, 2007, 06:15:20 AM »
No,
in VBA you can add a reference to a type library in the VBA editor. This makes the code know how a certain object model is build. I do not know if VB script has the same references.
But if it doesn't look for code editing the registry through API calls that way you don't need a reference.
HarleyHetz
« Reply #6 on: May 24, 2007, 08:16:04 AM »
Also, make DARN sure BEFORE you go poking around in your registry that you make a backup of it. You can hose your computer QUICK in there!!!!
ML
« Reply #7 on: May 24, 2007, 09:23:24 AM »
Yes,
I did back up The registry, I do realize it is treading in muddy waters.
In some instances, VBA can access some of the same objects that VBSCript can.
For instance, I believe you can access The FileSystemObject through VBA but I don't believe that in like The WSCript.Shell Object.
As far as I see, there doesn't seem to be an easy way to write to the registry via VBA.
It kind of pisses me off  :realmad: that AutoDesk will allow most paths to be set via The VBA API but for some odd reason, a few others are not accessible.
So, howelse do you set a path programmatically without going straight to the registry.
Anyone know a "finite" way to make this happen via VBA?
Dave R
« Reply #8 on: May 24, 2007, 10:19:30 AM »
Mark -
Try putting the code below in a .vbs file:
Dim WshShell
 Dim KeyName
 Dim ValueData
  KeyName = "HKEY_USERS\S-1-5-21-1749436377-938699083-1307212239-11542\Software\Autodesk\AutoCAD\R16.2\ACAD-4008:409\Profiles\Test\General\SheetSetTemplatePath"
    WshShell.RegWrite KeyName, ValueData
    Set WshShell = Nothing
  Dim WshShell
    WshShell = Nothing
Thank you,
ML
« Reply #9 on: May 24, 2007, 03:15:31 PM »
Hey Dave, thanks!
The below code worked! It wrote the path to the registry
Dim WshShell
Dim KeyName
Dim ValueData
In VBA, it worked by removing The Wscript and simply saying:
Dim WshShell
Dim KeyName as String
Dim ValueData as String
[b]Set WshShell = CreateObject("WScript.Shell")[/b]
However, neither one updated the path in my ACAD Profile which is the end result I need.
Any idea why it is not being updated in CAD?
Dave R
« Reply #10 on: May 24, 2007, 04:18:15 PM »
What Profile do you have set current?
ML
« Reply #11 on: May 24, 2007, 04:44:24 PM »
Profile "Test"
From what I understand or am learning; you can not write to the registry with ACAD open while using a vbs script.
Therefore, ACAD must be closed and not referenced in the code.
Dave R
« Reply #12 on: May 25, 2007, 07:58:14 AM »
Yes, I believe that is correct ACAD needs to be closed to write to a registry key, but if your original intention was to run the code from a VBScript wouldn't that be the case?
Profile "Test"
ML
« Reply #13 on: May 25, 2007, 12:18:03 PM »
Yes, you are correct but I made the mistake of adding a reference to The ACAD Application Object and that screwed me up. I have been doing VBA for a little while but scripting is very new to me and I am not real use to accessing other programs from CAD or outside of the application. I must admit, it is great stuff but I need to exercise a lot more care in doing so then I would with just customizing the software from within VBA.
For some reason, I was thinking I needed to open a session of CAD first, then write the code but I was mistaken.
I think I am getting on the right path now.
Dave R
« Reply #14 on: May 25, 2007, 02:43:36 PM »
Mark -
Since you're new to scripting you may want to take a stroll through here. There's a lot of good info to be had.
