Author Topic: Trouble with console app to rename files  (Read 8176 times)
« on: March 11, 2008, 01:17:22 PM »
I don't know what is wrong, and I don't understand why nothing will be printed to the command line.  I have added a lot of Console.WriteLine thinking that it would print out to the command line, but that doesn't seem to be working.  I'm lost and don't seem to be able to find out why.
Any help is appreciated.  Thanks.
using System;
using System.IO;
using System.Windows.Forms;
namespace WindosApps
/// <summary>
/// Description of RenameFiles_Console.
/// </summary>
public class RenameFiles_Console
private static void Main(string[] args)
try {
Console.WriteLine("Starting work.");
if ( (args == null) || ( !args.Length.Equals(3) ) ) {
Console.WriteLine("Arguements: <Path> <Series number> <Start sheet number>");
    return;
string DirPath = args[0] as string;
if ( !Directory.Exists(DirPath) ) {
Console.WriteLine("Directory does not exist.");
return;
Console.WriteLine("Done with directory.");
string SeriesPrefix = args[1] as string;
if ( !SeriesPrefix.Length.Equals(14) ) {
Console.WriteLine("Series number is not the correct length: <12-2xxx-xxxx-x>");
return;
Console.WriteLine("Done checking series number.");
int SheetNumber = Convert.ToInt16(args[2]);
if (SheetNumber <= 0) {
Console.WriteLine("Starting sheet number has to be greater than 0.");
return;
Console.WriteLine("Done checking sheet number.");
foreach (string str in Directory.GetFiles(DirPath, "*.dwg")) {
string tempNewPath = DirPath + "\\" + SeriesPrefix + "_" + SheetNumber.ToString() + ".dwg";
string tempOldPath = DirPath + "\\" + str;
File.Copy(tempOldPath, tempNewPath);
if ( File.Exists(tempNewPath) ) {
File.Delete(tempOldPath);
Console.WriteLine("Renamed " + tempOldPath + " -> " + tempNewPath);
else
Console.WriteLine("Could not rename file: " + tempOldPath);
++SheetNumber;
catch (System.Exception SysEx) { Console.WriteLine(SysEx.Message); }
finally {
Console.ReadLine();
return;
FengK
Re: Trouble with console app to rename files
« Reply #1 on: March 11, 2008, 01:25:43 PM »
Try commenting out this line?
« Reply #2 on: March 11, 2008, 01:28:54 PM »
Did help any.  I had put that in because the error wouldn't print to the command line, so in one version I put it in a MessageBox and that would show, but nothing I do will print to the command line.
David Hall
  • Automatic Duh Generator
« Reply #3 on: March 11, 2008, 01:39:37 PM »
I dont know if its your using statements, but
using System;
using System.Linq;
using System.Text;
using System.IO;
namespace tim
    class Program
            try
                if ((args == null) || (!args.Length.Equals(3)))
                    return;
                if (!Directory.Exists(DirPath))
                    return;
                if (!SeriesPrefix.Length.Equals(14))
                    return;
                    return;
                    if (File.Exists(tempNewPath))
                    else
                    ++SheetNumber;
            finally
                Console.ReadLine();
            return;
worked for me and printed things to the console
« Reply #4 on: March 11, 2008, 01:57:36 PM »
Thanks for trying Cmdr, but that didn't work for me.  I had some errors in my code, and once I fixed that the code worked, but it still wouldn't print to the command line.  I'm kind of lost still.  I guess I will have to do some more research on MSDN.  Here is the updated code that works.
using System;
using System.IO;
//using System.Linq;
using System.Text;
/// <summary>
/// </summary>
try {
    return;
//MessageBox.Show("1");
return;
//MessageBox.Show("2");
return;
//MessageBox.Show("3");
return;
string strSheetNumber = SheetNumber.ToString();
if (SheetNumber < 10)
strSheetNumber = "00" + strSheetNumber;
else if (SheetNumber < 100)
strSheetNumber = "0" + strSheetNumber;
string tempNewPath = DirPath + "\\" + SeriesPrefix + "_" + strSheetNumber + ".dwg";
//MessageBox.Show(tempOldPath + "\n" + tempNewPath);
File.Copy(str, tempNewPath);
File.Delete(str);
Console.WriteLine("Renamed " + str + " -> " + tempNewPath);
else
Console.WriteLine("Could not rename file: " + str);
++SheetNumber;
finally {
//Console.ReadLine();
return;
David Hall
« Reply #5 on: March 11, 2008, 02:20:37 PM »
Command line or Console line?  I am assuming you know this is a console app and has nothing to do with Autocad, but the use of Command line jumped out at me.  If you knew this already, just ignore me
« Reply #6 on: March 11, 2008, 02:26:08 PM »
I guess I'm just used to typing command line.  You are correct that I mean console line.  I didn't find anything on my search of MSDN, but maybe I will do a more thorough search when I have more time.  Thanks for trying.
Chuck Gabriel
« Reply #7 on: March 11, 2008, 02:34:57 PM »
When you started the project, what project type did you select?
David Hall
« Reply #8 on: March 11, 2008, 02:51:29 PM »
good question, I assumed that because of the use of Console.Writeline, he had started a console app.  When I copied and pasted, I started a console app and it worked for me. (Well it didn't really work, but it did print to console line)
« Reply #9 on: March 11, 2008, 03:31:52 PM »
I just selected class as the template.  I don't see a selection for console app.  Attached is the new file dialog from SharpDevelop.
David Hall
« Reply #10 on: March 11, 2008, 03:33:51 PM »
Well that would be the problem, I dont see any way to create a console app from that Pic
« Reply #11 on: March 11, 2008, 03:36:16 PM »
I guess I can search the SD web site, and forums, to see if I can find a way to do it then, if you persons think that is the problem.  I'll let you know what I find.
David Hall
« Reply #12 on: March 11, 2008, 03:38:06 PM »
What version of SD do you have? this site shows SD with a console app option.  If you go to File->New->Solution do you get a console app option
David Hall
« Reply #13 on: March 11, 2008, 03:39:21 PM »
I dont use SD, so I wont be of much help.  Sorry
« Reply #14 on: March 11, 2008, 03:49:20 PM »
I see that option in my version.  Didn't know I had to make a whole new solution (project) just to use an application in the console.  I will see if that works..... Be right back......
THAT WAS THE PROBLEM!!  Thank you!  Now I know how to make console apps that will work.
