I have not had any problems saving to 2000 or 2002 file format from AutoCAD 2005.
Its may be something in your drawings that is causing an error in 2002.
I would audit your drawing if you have not already done so.
If that fails try the old ‘Wblock’, ‘All’. That always solves the problem for me in the end.
Good luck....
