Code Red => AutoLISP (Vanilla / Visual) => Topic started by: cadman6735 on May 29, 2014, 10:53:02 AM
I can not figure out why this will not work? "too few arguments" :realmad: I am arguing with it and it still won't work... :ugly:
(vlax-for eachLayer acLayers
(if (eq (wcmatch (strcase (vla-get-name eachLayer)) "*A-ANNO-SEAL"))
(vla-put-freeze eachLayer :vlax-true)
Hey
try this, can't test it...
(if (wcmatch (strcase (vla-get-name eachLayer)) "*A-ANNO-SEAL")
removed the (eq
reltro
Seriously???
Thank you very much....
Please note that in AutoCAD 2015, you cannot use a pattern like "*A-ANNO-SEAL" as it is treated the same as "*", which I learned the hard way yesterday. The * must be in the middle or at the end of the string only.
I cannot reproduce this behavio(u)r :?
How strange, it's what was happening to me yesterday.
