Author Topic: Switch Block Attribute Value According to List  (Read 1007 times)
BHenry85
  • Mosquito
« on: August 09, 2022, 01:56:48 PM »
Hello All,
I have a detail bubble block that is used for over 1000+ details. We use the external hyperlink, not the one within the block, property to link to a published detail in BIM 360 for each detail. The block name is "DetailBubble" and it has two attributes that we use called "SHEET_NUMBER" and "DETAIL_NUMBER". I have lisp that reads through all of the insertions of this block and will list these attributes combined together (EX: Detail Number (1) + Sheet Number (D1) = 1-D1) and the hyperlink within a CSV file. There are times when the hyperlink will be incorrect or changes and we have to update these links in any drawing that references that detail. This can be a vary tedious process on our users manually and I am looking for a way that I can automate this process. I would need something that first can take detail information in column a (1-D1) and separate those, run a search through all "DetailBubble" block insertions and find any that might match those values (DETAIL_NUMBER = 1, SHEET_NUMBER = D1), and then when it finds a match, replace the hyperlink with what is listed in column B in the CSV file. Before any one states, yes I have searched far and wide for something that might fit the bill, but I have only found something that would replace the hyperlink across ALL block insertions that have that name or others suggesting to do a find and replace which will not work in this scenario because broken links will have the same starting path as working hyperlinks. I have included some reference files that someone can test with and I appreciate anyone that can help on this in advance.
« Last Edit: August 09, 2022, 06:59:45 PM by BHenry85 »
BIGAL
  • 40 + years of using Autocad
Re: Switch Block Attribute Value According to List
« Reply #1 on: August 09, 2022, 08:08:59 PM »
As your excel file is unique to a dwg have you looked at adding the "Handle" to your xl this way a row of values is directly connected to a block so you can get that 1 block instantly. The only thing is does object exist check.
Google "handle autocad"  "Handent Autocad"
mhupp
« Reply #2 on: August 09, 2022, 09:09:11 PM »
Was just going to say that BIGAL.
You could just skip outputting to the spread sheet entirely and modify the original lisp to first if the link is valid.
  1. (if (< (strlen hyprlnk) 208)
if its not search the other spread sheet that has valid links for the "SHEET_NUMBER" - "DETAIL_NUMBER" with a read loop to find the row number then use that to pull the valid link.
might be a little slow to process all the blocks but would be faster then making a second spread sheet using vlookup to get right links. then using another lisp to input those values back into the drawing.
« Last Edit: August 10, 2022, 12:16:19 AM by mhupp »
mhupp
« Reply #3 on: August 10, 2022, 03:07:42 PM »
Looks like RLX has something kinda like that but searches for x y z coords.
https://www.cadtutor.net/forum/topic/67036-lines-to-search-in-excel/?do=findComment&comment=548552
BHenry85
  • Mosquito
« Reply #4 on: August 15, 2022, 10:33:39 AM »
Apparently my last comment only took the quote and not anything else around it. I was wondering why I wasn't getting any responses and assumed I annoyed you both.
Hey @mhupp! Nice to see you again and thank you for your previous help on the first phase of this project located here:
https://www.cadtutor.net/forum/topic/75699-remove-duplicates-in-list/
I don't think that modifying the original script would help because I need something that first identified if there is an issue and then now another that would resolve it. I reviewed the lisp linked above and it looks like it would need a massive overhaul that is all way above me in order for it to fit my use case. We could change the initial script to leave the "SHEET_NUMBER" and "DETAIL_NUMBER" attributes in separate columns if that would aid the process of identifying the detail callouts that have incorrect hyperlinks and need to be corrected. Again, and as always, I greatly appreciate any and all help on the matter.
