Author Topic: Importing Aerial Information with a JPG and JPW  (Read 5275 times)
MSTG007
« on: June 16, 2005, 11:11:23 AM »
Anyone know how to import an image with a jpw world file?
thanks!
Civil3D 2020
« Reply #1 on: June 16, 2005, 11:28:31 AM »
OPen the jfw with note pad and sii if it has some thing similar to this in it:
http://duff.ess.washington.edu/data/raster/drg/tfw.html
Scott
« Reply #2 on: June 19, 2005, 10:50:19 PM »
Are you using Autodesk Map?
MSTG007
« Reply #3 on: June 20, 2005, 08:44:30 AM »
i have it... how to i place it in there?
thxs
Civil3D 2020
kevin
« Reply #4 on: June 20, 2005, 05:32:27 PM »
If the world file is ok and in the same folder as the jpg.  Go to Map->Image->Insert.  It should read the world file and insert the image correctly.  I usually only use MrSID and Tiff fille though.  Check the units also, and let me know if I missed something.
airportman
  • i customize when required
« Reply #5 on: August 15, 2005, 04:54:25 PM »
as stated by the other guys. that file is a world file for use with the geo-referenced tiff or jgp image. we use
RASTER DESIGN to work with our aerial images and ortho-rectified files.
acad MAP may not place it in the correct location.
give it a try
Perception is a state of mind  -/ Twitter = @hochanz -/ Intel i7 - 3.07GHz -/ 12GB Ram -/ Nvidia Quadro FX 1800
Scott
« Reply #6 on: August 17, 2005, 11:25:43 PM »
Make sure you jpeg and your world file are named the same and in the same directory.
