Hi all,
I am looking at a task for which I can't see a solution. Perhaps i'm not looking outside of the box.
We have a model and end sheets setup. Base model > multiple end sheets that reference the base model.
Within the base model I xref (attach) the arch background, grids etc.
Within the sheet file, on the title block I want to have a field / diesel expression that looks specifically at the arch xref, and displays two custom "drawing properties" the purpose is to show the original file reference and original file revision.
Thus, one update of the base xref will update hundreds of sheets with this info.
Is that clear as mud?!
