Challenge ( cylinder volume )
MP:
Another fun variant --
--- Code: ---(defun c:foo ( / foo )
(defun foo ( pmt ) (initget 7) (getdist pmt))
(princ
(strcat "Volume of cylinder = "
(rtos
( (lambda ( radius height )
(* pi
(expt radius 2)
height
(foo "\nEnter radius: ")
(foo "\nEnter height: ")
--- End code ---
MP:
And for a daffy combination of the two previous variants --
--- Code: ---(defun c:foo ( )
(princ
(rtos
( (lambda ( foo )
(* pi
(expt radius 2)
height
(lambda ( pmt ) (initget 7) (getdist pmt))
--- End code ---
:P
whdjr:
Here's mine:
--- Code: --- ;Calculate the volume of a cylinder given diameter and height. However,
;to make it a challenge you can not use any variables. You must prompt
;the user for for both diameter and height, include error checking for
;negative numbers, zero and <enter>. Local functions are allowed.
;Cylinder pi * radius2 * height
(defun c:cylinder (/ ask sq)
(defun ask (msg)
(initget 7)
(getreal msg)
(defun sq (num)
(* num num)
(princ
(strcat "\nCylinder Volume: "
(rtos (* pi
(sq (ask "\nEnter Diameter for Cylinder: "))
(ask "\nEnter Height for Cylinder: ")
2
--- End code ---
Mark:
Will I'd say you copied my idea but you posted first. :-)
--- Code: ---(defun c:cubevol ( / ask)
(defun ask (msg)
(initget 7)
(getreal msg)
(princ
(strcat "Volume = "
(rtos
(* pi
(expt (/ (ask "\nDiameter: ") 2) 2)
(ask "\nHeight: ")
--- End code ---
Kerry:
Nice challenge Mark .. :-)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
