;;program name : 캐드내 사칙연산프로그램 ver 1.0
;;program : +, -, /, * 가지고 텍스트 계산 다 됨
;;Modified by KDUB (in theswamp)
;;https://www.theswamp.org/index.php?topic=52639.0
(defun exe_1()
(setvar "cmdecho" 0)
(setvar "blipmode" 0)
(setq e1 (entsel "\n>>첫번째숫자선택:"))
(setq a (car e1);;----------엔티티의 이름값
b (entget a);;--------엔티티의 리스트값
txt1 (assoc 1 b);;----엔티티중 해당 문자열 리스트
tt1 (cdr txt1);;------엔티티 문자열의 리스트중 뒤의값="문자열"
sum1 (atof(_removecommas-fromstring tt1));;-----엔티티의 문자열을 정수로 변환=100
txth1 (assoc 40 b);;--엔티티 리스트중 텍스트 높이의 리스트값(40,100)
thh (cdr txth1);;-----엔티티의 텍스트높이의 리스트중 뒤의값=100
(setq e2 (entsel "\n>>두번째숫자선택:"))
(setq aa (car e2)
bb (entget aa)
txt2 (assoc 1 bb)
tt2 (cdr txt2)
sum2 (atof(_removecommas-fromstring tt2))
(setq tl (assoc 8 b)
txtst (cdr tl)
(defun exe+()
(setq sum (+ sum1 sum2))
(setq summ (rtos sum 2 3))
(setq p1 (getpoint "\n>>표시할 포인트찍기:"))
(command "text" p1 thh 0 summ)
(defun exe-()
(setq sum (- sum1 sum2))
(defun exe*()
(setq sum (* sum1 sum2))
(defun exe/()
(setq sum (/ sum1 sum2))
(defun exe%()
(setq sum (* (/ sum1 sum2) 100))
(defun c:+( / e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe+)
(defun c:-( / e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe-)
(defun c:*( / e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe*)
(defun c:/( / e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe/)
(defun c:%( / e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe%)
(defun c:py( / e1 a b txt1 tt1 sum1 txth1 thh sum summ p1 )
(setq e1 (entsel "\n>>숫자선택:"))
(setq sum (* sum1 0.3025))
(setq zz (strcat "(" summ ")"))
(command "text" p1 thh 0 zz)
(defun c:+( / sum_m ss ok e ent sum_ p1 txth1 thh summ )
(setq sum_m 0)
(setq SS (ssget))
(setq ok 0)
(while
(setq e (ssname ss ok))
(setq ent (entget e))
(setq sum_ (assoc 1 ent))
(setq sum_ (cdr sum_))
(setq sum_ (atof(_removecommas-fromstring sum_)))
(setq sum_m (+ sum_m sum_))
(setq ok (1+ ok))
(setq txth1 (assoc 40 ent))
(setq thh (cdr txth1))
(setq summ (rtos sum_m 2 3))
(defun c:*( / sum_m ss ok e ent sum_ p1 txth1 thh summ )
(setq sum_m 1)
(setq SS (ssget))
(setq ok 0)
(while
(setq sum_m (* sum_m sum_))
(setq ok (1+ ok))
(princ "\n>>사칙연산 프로그램 로딩완료 command : +,-,*,/,%,py,++,**")
(defun _removecommas-fromstring (str)
(while (vl-string-search "," str) (setq str (vl-string-subst "" "," str)))
str
Mr. Lee.
I changed All "rtos sum_m 2 3" to "rtos sum_m 3" in that code.
But It doesn't work.
I got <453'-4"> as a result when I add <3,340> to <15,930>.
