not the same in some respects. it was better organized and far more important, code wouldn't sink.
I´ve learned a lot by looking at the Filefind code at CV Codearchive it introduceud API and collections to me. I´m sure I would not have found it if it was on page 8 of the link you provided.
What do you think about a code archive link like CV had Kerry?
I won´t request it if there´s no support to build it.
While I cannot speak for Mark (site owner) or the other the moderators, I would suspect that a couple of things would likely not ever happen.
a) theswamp.org will not take the same path as other forums
b) theswamp.org does not seek to be "like" any other forum, currently operating or not.
You have an array of tools to use that you can use to do exactly what you want. As far as I know you can archive code in the
CVS repository you can post it in
this thread, you can upload it to the
lilly pond, you can just leave it in the thread where it is ....
At any rate, this is what we have to work with .. like it or not ... you can suggest that a code archive be added in the
Suggestion Box Forum
