Author Topic: truncated sum  (Read 1291 times)
danadrian.baluta@yahoo.co
truncated sum
« on: July 06, 2018, 05:09:59 AM »
Hello,
I don't remember seeing this before.
If i try
  1. (+ 500000.0 123.234)
i get
500123.0
If I do the same thing with the CAL command in AutoCAD, i get 500123.234.
How can I get Autolisp to not truncate the sum?
Thank you,
Adrian
kpblc
Re: truncated sum
« Reply #1 on: July 06, 2018, 05:17:06 AM »
Change LUPREC system variable to 4. Or use smth like this:
  1. (rtos (+ 5e5 123.234) 2 14)
Sorry for my English.
Re: truncated sum
« Reply #2 on: July 06, 2018, 05:47:56 AM »
Thank you for the answer.
LUPREC doesn't seem to influence this. It was set to 8.
I tried your trick and it works. But it needed the real number, not the text.
So i decided to give it a go with the truncated numbers. I needed to draw a polyline with these numbers.
To my surprise, the coordinates were correct, with all the decimal places. So it's just a matter of displaying them truncated, not actually truncating them.
Weird.
Thanks,
Adrian
kpblc
Re: truncated sum
« Reply #3 on: July 06, 2018, 05:52:48 AM »
The real value is 500123.234 - you can check it:
  1. (* (+ 5e5 123.234) 1e3)
