Sofar, Tim Riley comes the closest to what I need. I found a VBA snippet that uses a rather cryptic way to check a file's existance, so even uncompiled the code doesn't give itself away easily. Also, I could use it as a time bomb, e.g. mess up a variable of which the value will be used somewhere else in the program.
