Author Topic: PL2CLOUD27  (Read 3111 times)
POCKETS
PL2CLOUD27
« on: January 14, 2009, 03:13:36 PM »
Cab,
 I like your program, Pl2cloud27. It's the best revision cloud around.  BUT I have a problem.  I have added pl2cloud to the start up suite of the load application so that it will load every time I call up a drawing.  The thing is, I get a "too many arguments" at the command line when I type in PL2CLOUD. I can reload from the Load Application and it works fine. I am using AutoCAD 2002. Do you know what the problem might be?
Pockets
Re: PL2CLOUD27
« Reply #1 on: January 14, 2009, 04:15:14 PM »
Try taking it out of the Startup suite & add this
(AUTOLOAD "PL2Cloud27" '("PL2Cloud")) ; Draw Revision Cloud from Plineto acaddoc.lsp or any other lisp that is loaded in each DWG.
PS Thanks 8-)
POCKETS
Re: PL2CLOUD27
« Reply #2 on: January 15, 2009, 08:26:32 AM »
Cab. Thank you!
skennedy
Re: PL2CLOUD27
« Reply #3 on: January 15, 2009, 08:29:45 AM »
I also must say that I think that this is the best Revcloud Prog I've seen.
Re: PL2CLOUD27
« Reply #4 on: January 15, 2009, 09:31:02 AM »
Thanks fellas.
Krushert
  • FREE BEER Tomorrow!!
Re: PL2CLOUD27
« Reply #5 on: January 15, 2009, 09:41:56 AM »
Alright!  Now you are going to make me go look it up and try it out.
Re: PL2CLOUD27
« Reply #6 on: January 15, 2009, 10:09:14 AM »
I assume you found it.
If not:
 http://www.theswamp.org/index.php?topic=1319.0
GDF
Re: PL2CLOUD27
« Reply #7 on: January 15, 2009, 10:32:52 AM »
Alan
Great routine. I have one that is similar. In mine I added delta symbol, text and arrow. Also a toggle to a Red Line Cloud tool with cloud, text and arrow.
This is part of my overall program, so it is not a seperate standalone routine. Just thought I would tease you will some ideas. I have learned a lot from your routines. My codes are weak, but I love creating dialog boxes.
POCKETS
Re: PL2CLOUD27
« Reply #8 on: January 15, 2009, 11:25:13 AM »
Krushart,
No one is going to make you look it up but if you don't you are going to miss out on a great revision cloud program.
Pockets
Krushert
Re: PL2CLOUD27
« Reply #9 on: January 15, 2009, 11:28:59 AM »
Krushart,
Pockets
I will get there guys, Too busy right now to play with it.
Thanks for the link CAB
Re: PL2CLOUD27
« Reply #10 on: January 15, 2009, 12:54:29 PM »
Gary, you're a master at Dialog Design. 8-)
dustinthiesse
Re: PL2CLOUD27
« Reply #11 on: January 15, 2009, 02:58:31 PM »
Dialog boxes make my head hurt.  I like coding them, but I've never done anything as sweet looking as yours, Gary.  Keep up the good work.
adalea03
Re: PL2CLOUD27
« Reply #12 on: January 24, 2009, 08:02:04 AM »
He sure is.
Tony
