Author Topic: API WishList VLIDE  (Read 2646 times)
Jeff H
API WishList VLIDE
« on: May 26, 2011, 03:11:28 AM »
I did not know how many of you make it over to .NET threads, but
one of the options is to update IDE for lisp
http://through-the-interface.typepad.com/through_the_interface/2011/05/api-wishlist-surveys-for-autodesk-products.html
Re: API WishList VLIDE
« Reply #1 on: May 26, 2011, 04:39:43 AM »
If I recall correctly the same item scored very highly last year ... perhaps this year someone will pay attention ( providing the option gets some votes :) )
« Reply #2 on: May 26, 2011, 09:19:35 AM »
Just voted  :wink:
gile
  • Marseille, France
« Reply #3 on: May 26, 2011, 01:37:03 PM »
And if I remember, last year, there was also a DCL enhancement option which had a good score too, sadly this seems to be given up...
dgorsman
« Reply #4 on: May 26, 2011, 02:58:39 PM »
Thanks for the link.   :-)
With the ActiveX-less/DCL-less LISP in the Mac release, they may be limiting improvements to those which can apply across both platforms to avoid rework or painting themselves into a corner down the road.  That position is probably bolstered by the presence of Action Recorder and Managed .NET support as LISP alternatives, too.
A lot of these surveys are pointing towards a new scripting interface.  Some days I'm worried they are looking at ditching LISP in favor of whatever that turns into.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Jeff H
« Reply #5 on: May 26, 2011, 03:32:21 PM »
hermanm
« Reply #6 on: May 26, 2011, 10:28:37 PM »
One of the options listed is: Dynamic .NET interface
It would be *really* sweet to be able to be able to use a .NET language interactively with ACAD (if I understand this option correctly).
IOW, to be able to write, let's say, Python, or F#, etc. on the fly, just as we do AutoLISP, and be able to unload/reload .NET dlls...
dgorsman
« Reply #7 on: May 27, 2011, 12:02:27 PM »
I was kind of curious about that one, myself.  I'd like to see further information on what they mean.  It could be a means of compiling to MSIL or other intermediary, then using an interpreter to run that as a scripted process.  Or it could be a GUI drag'n'drop system with pre-assembled blocks of .NET code that you drag around and visually connect in a program flow diagram.
try {GreatPower;}
   finally
      {MasterBasics;}
