Author Topic: Stack functions - Push/Pop/Roll - needed  (Read 4802 times)
mkweaver
« on: August 16, 2012, 03:51:29 PM »
I'm looking for a few data stack routines - specifically push, pop, rollup and rolldown.  I did a google search and got a fair number of hits for common lisp, but nothing for lisp.
I have put together the following but am open to suggestions:
  (defun ListRollUp(lst /)
    ;;'(1 2 3) becomes (3 1 2)
    (cons (car(reverse lst)) (reverse (cdr (reverse lst))))
  (defun ListRollDown(lst / )
    ;;'(1 2 3) becomes (2 3 1)
    (reverse (cons (car lst) (reverse (cdr lst))))
Any suggestions are welcome.
Mike
irneb
Re: Stack functions - Push/Pop/Roll - needed
« Reply #1 on: August 16, 2012, 04:11:25 PM »
Perhaps for push, pop & peek:
  1. (defun ListPush (lst item / )
  2.   (cons item lst))
  3.
  4. ;;; Use by quoting the list, e.g.
  5. ;;; (setq lst '(1 2 3))
  6. ;;; (setq item (ListPop 'lst))
  7. ;;; Now item=1 and list=(2 3)
  8. (defun ListPop (lst / item)
  9.   (setq item (car (eval lst)))
  10.   (set lst (cdr (eval lst)))
  11.   item)
  12.
  13. ;;; Rather trivial!
  14. (defun ListPeek (lst)
  15.   (car lst))
Unfortunately we don't have the setf function in AutoLisp - otherwise the pop would be a lot simpler.
irneb
« Reply #2 on: August 16, 2012, 04:29:56 PM »
Or a destructive implementation (the stack needs to be quoted for each function):
  1. (defun stack:push (stack item) (set stack (cons item (eval stack))))
  2.
  3. (defun stack:pop (stack / tmp) (car (cons (car (setq tmp (eval stack))) (set stack (cdr tmp)))))
  4.
  5. (defun stack:peek (stack) (car (eval stack)))
  6.
  7. (defun stack:rollup  (stack / tmp)
  8.   (set stack (cons (car (setq tmp (reverse (eval stack)))) (reverse (cdr tmp)))))
  9.
  10. (defun stack:rolldown  (stack / tmp)
  11.   (set stack (append (cdr (setq tmp (eval stack))) (list (car tmp)))))
Edit: RollDown was implemented incorrectly - changed  :-[
« Last Edit: August 16, 2012, 04:37:18 PM by irneb »
« Reply #3 on: August 16, 2012, 04:42:04 PM »
Some variations:
  1. (defun push ( x l )
  2.     (cons x l)
  3. )
  4. (defun pop ( l )
  5.     (cdr l)
  6. )
  7. (defun rollup ( l )
  8.     (cons (last l) (reverse (cdr (reverse l))))
  9. )
  10. (defun rolldown ( l )
  11.     (append (cdr l) (list (car l)))
  12. )
roy_043
  • BricsCAD 18
« Reply #4 on: August 16, 2012, 06:02:17 PM »
@ irneb:
Your (stack:pop) function (reformatted for clarity):
  1. (defun stack:pop (stack / tmp)
  2.   (car
  3.     (cons
  4.       (car (setq tmp (eval stack)))
  5.       (set stack (cdr tmp))
  6.     )
  7.   )
  8. )
Why not:
  2.   (set stack (cdr (setq tmp (eval stack))))
  3.   (car tmp)
  4. )
@ Lee:
Your (pop) does not return the popped item...
« Reply #5 on: August 16, 2012, 06:08:09 PM »
@ Lee: Your (pop) does not return the popped item...
Sorry, I was unaware of the standard behaviour of these functions... I will revise  :-)
« Reply #6 on: August 16, 2012, 06:25:35 PM »
The push and pop I use work with a quoted list.
This allows the popped value to be returned AND have the original list value modified.
  1.
  2. ;;;------------------------------------------------------------------
  3. ;;;------------------------------------------------------------------
  4. ;;;
  5. ;;; push first element into quoted list
  6. ;;; example :
  7. ;;;  (setq tmp_list '( ) )
  8. ;;;  (setq tmp_list (KDUB:LIST-pUSH "teststring" 'tmp_list ))
  9. ;;;                  ==>  ("teststring")
  10. ;;;  (setq tmp_list (KDUB:LIST-pUSH (getvar "CMDECHO") 'tmp_list ))
  11. ;;;                  ==> (1 "teststring")
  12. ;;;  (setq tmp_list (KDUB:LIST-pUSH (cons "BLIPMODE" (getvar "BLIPMODE")) 'tmp_list ))
  13. ;;;                  ==> (("BLIPMODE" . 0) 1 "teststring")
  14. ;;;  (setq tmp_list (KDUB:LIST-pUSH (cons "EXPERT" (getvar "EXPERT")) 'tmp_list ))
  15. ;;;                  ==> (("EXPERT" . 2) ("BLIPMODE" . 0) 1 "teststring")
  16.
  17. (defun kdub:list-push (push_value quoted_lstsym)
  18.   (set quoted_lstsym (cons push_value (eval quoted_lstsym)))
  19. )
  20. ;;;------------------------------------------------------------------
  21. ;;;------------------------------------------------------------------
  22. ;;;
  23. ;;; pop first element permenantly from quoted list
  24. ;;; and return this element's value
  25. ;;; example :  using previuusly set tmp_list
  26. ;;;  (KDUB:list-pop 'tmp_list)  ==> ("EXPERT" . 2)
  27. ;;;             tmp_list now= (("BLIPMODE" . 0) 1 "TESTSTRING")
  28.
  29. (defun kdub:list-pop (quoted_lstsym / tmp)
  30.   (setq tmp (eval quoted_lstsym))
  31.   (set quoted_lstsym (cdr tmp))
  32.   (car tmp)
  33. )
  34.
  35.
  36. ;;;------------------------------------------------------------------
  37. ;;;------------------------------------------------------------------
« Reply #7 on: August 16, 2012, 06:29:36 PM »
In c++ pop does not return the item off the stack, although it could be written to do that.
« Reply #8 on: August 16, 2012, 06:50:42 PM »
An attempt to imitate C++ (I have almost no experience in C++, does it show?  :-D )
  1. ;; http://www.cplusplus.com/reference/stl/stack/push/
  2. ;; (setq lst '(0 1 2 3 4 5))
  3. ;; (stack::push 6 'lst) ==> lst = (6 0 1 2 3 4 5)
  4. (defun stack::push ( x *stack* )
  5.     (set *stack* (cons x (eval *stack*)))
  6.     (princ)
  7. )
  8.
  9. ;; http://www.cplusplus.com/reference/stl/stack/pop/
  10. ;; (setq lst '(0 1 2 3 4 5))
  11. ;; (stack::pop 'lst) ==> lst = (1 2 3 4 5)
  12. (defun stack::pop ( *stack* )
  13.     (set *stack* (cdr (eval *stack*)))
  14.     (princ)
  15. )
  16.
  17. ;; http://www.cplusplus.com/reference/stl/stack/top/
  18. ;; (setq lst '(0 1 2 3 4 5))
  19. ;; (stack::top 'lst) ==> 0
  20. (defun stack::top ( *stack* )
  21.     (car (eval *stack*))
  22. )
  23.
  24. ;; http://www.cplusplus.com/reference/stl/stack/size/
  25. ;; (setq lst '(0 1 2 3 4 5))
  26. ;; (stack::size 'lst) ==> 6
  27. (defun stack::size ( *stack* )
  28.     (length (eval *stack*))
  29. )
  30.
  31. ;; http://www.cplusplus.com/reference/stl/stack/empty/
  32. ;; (setq lst '( ))
  33. ;; (stack::empty 'lst) ==> T
  34. (defun stack::empty ( *stack* )
  35.     (null (eval *stack*))
  36. )
« Reply #9 on: August 16, 2012, 06:54:55 PM »
Stating the obvious : each language may have a different implementation.
C# and VB.net
Stack.Pop Method
Removes and returns the object at the top of the Stack.
Stack.Pop is similar to the Peek method, but Peek does not modify the Stack.
« Reply #10 on: August 16, 2012, 07:11:37 PM »
C# and VB.net
Stack.Pop Method
Absolutely ...
I had some extensive discussion with some folks about why C++ does not return the value on pop, and the reason I was given by most was that the C++ stack deals with pointers and when the stack is empty, pop does nothing. Popping an empty stack with a return value thus should return nil in lisp.
« Reply #11 on: August 16, 2012, 07:17:03 PM »
 Some do :)
  1. (setq empty_list '())
  2.
  3. (setq result (kdub:list-pop 'empty_list))
  4.
  5. ;;result == nil
  6.
irneb
« Reply #12 on: August 17, 2012, 06:27:16 AM »
@ irneb:
Why not:
  3.   (car tmp)
  4. )
Thanks yes ... that's probably a better implementation  ;)
It seems correct for only C++ http://www.cplusplus.com/reference/stl/stack/
 Though from my experience all the other languages I've come across returns the head item after removing it from the list/array (whichever implementation it's using). Basically the same manner as here (compared in C/C++/Java): http://www.cs.utsa.edu/~wagner/CS2213/stack/stack.html
 As for poping off an empty stack ... 2 options: (1) return null, (2) throw exception. Depends on how you implement the stack, probably you'd have to use a linked-list / array of pointers (or extend one of the collection classes if such exists in your language).
 Actually in Lisp such things as queues and stacks are already "implemented" ...
 http://www.lispworks.com/documentation/HyperSpec/Body/m_pop.htm#pop
 And for the roll's:
Code - Lisp: [Select]
  1. (defmacro stack-rolldown (stack)
  2.    `(setf ,stack (append (cdr ,stack) (list (car ,stack)))))
  3.
  4.  (defmacro stack-rollup (stack)
  5.    `(setf ,stack (append (last ,stack) (butlast ,stack))))
Seems to work here:
ECL-0.9i % (defparameter st (list 1 2 3))
 ST
 ECL-0.9i % st
 (1 2 3)
 ECL-0.9i % (stack-rolldown st)
 (2 3 1)
 ECL-0.9i % st
 (2 3 1)
 ECL-0.9i % (stack-rollup st)
 (1 2 3)
 ECL-0.9i % st
 (1 2 3)
mkweaver
« Reply #13 on: August 20, 2012, 09:07:51 AM »
Thanks for all the examples and discussion.  Good food for thought.
I guess I hadn't considered quoting the incoming list so the routine could modify it.  That's a much better approach than where I was headed.
Mike
