I'm using my own code:
(defun c:movrot () (b-cmr "M")(princ))
(defun c:coprot () (b-cmr "C")(princ))
; File : mcr.lsp
; Date : 20-9-03
; Function : (B-CMR <MODE>)
; Purpose : Copy+Rotate or Move+Rotate
; Arguments : <MODE> = "C" -> Copy-rotate
; = "M" -> Move-rotate
; Written by : J.J.Damstra
(defun b-cmr (typ / ss1 temp p0 p1)
(setq ss1 (ssget "I"))
(command ".undo" "begin")
(setq temp (getvar "CMDECHO"))(setvar "CMDECHO" 0)
(if (not ss1)(setq ss1 (ssget)))
(if ss1
(initget 1)
(setq p0 (getpoint "\nBasepoint : "))
(if (= typ "C")
(setq p1 (getpoint "\nTranslation or <ENTER>: " p0))
(if (not p1)(setq p1 p0))
(command ".copy" ss1 "" "0,0" "0,0")
(while (not p1)(setq p1 (getpoint "\nTranslation : " p0)))
(command ".move" ss1 "" p0 p1)
(command ".rotate" ss1 "" p1 pause)
(princ "\nMsg> Nothing selected! ")
(command ".undo" "end")
(setvar "CMDECHO" temp)
All examples in this topic have a minor bug: The translation is performed with the selected objects, but the selected objects shouldn't be moved!
If you now use PREVIOUS to make a selection in the next command you don't get what expect, but the 'new' objects.
In my example after the COPY-command you should make a new selection with the new objects.
