Author Topic: Adding Datum and Coordinate code to title block  (Read 1529 times)
everblader
« on: July 13, 2012, 02:58:46 PM »
Is there a way to display the projection (FL-W83) or Datum (NAD83) of a DWG file (Civil3D) in the titleblock? I am not very good at programming and was wondering if anyone had done this.
EB
jvillarreal
Re: Adding Datum and Coordinate code to title block
« Reply #1 on: July 13, 2012, 03:54:13 PM »
What would you want the code to do exactly?
If you're wanting to have a routine place the text for you in each drawing, it's possible..
You can get the projection with this function:
(ade_projgetwscode)
Jeff_M
  • C3D user & customizer
« Reply #2 on: July 13, 2012, 04:08:08 PM »
What is the name of the Title block and which attributes (Tag names) do you want the data input to? I showed you how to get the required data on the Autodesk C3D forum, you never mentioned that you didn't know how to do the rest of the code.
