Author Topic: (challange - newbie) in between two numbers  (Read 7652 times)
« on: January 05, 2005, 11:07:09 AM »
I want a way to see if a number is inbetween to numbers.
For example:
Is the number 4 inbetween the numbers 2 89?
Write a lisp that will tell me. The lisp should return either "T" or "nil"
Rules: Make a post when you have your lisp complete. After three hours we will post our lisp solutions.
« Reply #1 on: January 05, 2005, 11:40:10 AM »
I can name that tune in 23 characters.... of course I am not a newbie ..
whdjr
« Reply #2 on: January 05, 2005, 11:40:51 AM »
Ah man.  Why you gotta go put rules on this one? :D
CADaver
« Reply #3 on: January 05, 2005, 01:12:21 PM »
Quote from: Keith
Are you counting spaces?
dubb
« Reply #4 on: January 05, 2005, 01:17:53 PM »
are there any hints...?
« Reply #5 on: January 05, 2005, 01:28:05 PM »
Sure dubb, Use a logical test.
« Reply #6 on: January 05, 2005, 01:41:57 PM »
Quote from: CADaver
Quote from: Keith
Counting spaces
« Reply #7 on: January 05, 2005, 01:46:06 PM »
Okay, anyone done yet?
whdjr
« Reply #8 on: January 05, 2005, 01:57:26 PM »
(defun inbetween (num1 num2 num3)
  (and (> num1 num2)
       (< num1 num3)
Here's mine.
« Reply #9 on: January 05, 2005, 02:03:53 PM »
< post deleted >
« Reply #10 on: January 05, 2005, 02:04:27 PM »
Outstanding!
Why did you choose "and"?
whdjr
« Reply #11 on: January 05, 2005, 02:06:57 PM »
Quote from: Se7en
Outstanding!
Because with and they both have to be true or it's false.
You did ask for a T or nil answer.
« Reply #12 on: January 05, 2005, 02:13:21 PM »
Optimized for size ... functionalized ... essentially the same as Will's ...
(defun inbetween (@t @l @u)
  (and(< @l @t)(> @u @t))
« Reply #13 on: January 05, 2005, 02:19:47 PM »
< post deleted >
« Reply #14 on: January 05, 2005, 02:22:45 PM »
Quote from: whdjr
Aweosme!
Now, Can you tell me any problems you might see with this procedure the way it is?
