Author Topic: Choose a color  (Read 3496 times)
DanB
Choose a color
« on: January 26, 2006, 03:26:32 PM »
As part of another lisp I am working on I wanted to utilize the command "color" which brings up the select color dialog. Any reason this does not "pop up" when run in the following code?
(defun c:coloring (/ oldecho oldcolor newcolor)
 (setq oldecho (getvar "cmdecho"))
 (setvar "cmdecho" 1)
 (setq oldcolor (getvar "cecolor"))
 (command ".color" pause)
 (setq newcolor (getvar "cecolor"))
 (prompt (strcat "\nThe OLD color was <" oldcolor "> and the NEW color is <" newcolor ">"))
 (setvar "cmdecho" oldecho)
Thanks,
Dan
Re: Choose a color
« Reply #1 on: January 26, 2006, 03:32:48 PM »
Try this.
(setq xclr (acad_colordlg 252))
The 252 at the end is the default value I wanted, you can change it if you like.
DanB
Re: Choose a color
« Reply #2 on: January 26, 2006, 04:24:25 PM »
Thanks, I think that will work, going to need to try it out though...
CADmium
Re: Choose a color
« Reply #3 on: January 27, 2006, 02:40:04 AM »
look here .. scroll down to  "Adding the ability to select True Colors to your LISP programs"
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
Re: Choose a color
« Reply #4 on: January 27, 2006, 09:39:52 AM »
Welcome to the Swamp Lee.
Nice web site, thanks. :-)
