Author Topic: open specific sheet in excel  (Read 2679 times)
andrew_nao
« on: February 23, 2009, 03:12:11 PM »
I have this code that will allow me to write to a specific cell in excel
however im fumbling about trying to figure out how to open an excel file to the specific sheet to write to
can anyone post a sample syntax on how to open an excel file to a specific sheet?
here is the code that i have
thanks
;to make a link between acad and Excel (ok with Excel 97)
(setq ObjExcel (vlax-get-or-create-object "Excel.Application"))
(setq ObjWorkbooks (vlax-get-property ObjExcel "workbooks"))
(setq ObjCurrWorkbooks (vla-add ObjWorkbooks))
(setq ObjSheet (vlax-get-property ObjExcel "activesheet"))
(setq ObjCells (vlax-get-property ObjSheet "cells"))
;to put a value in a cell
(setq lineXls 4)
(setq rowXls 6)
(setq valueXls  "test")
(vlax-put-property ObjCells 'item lineXls rowXls valueXls)
Re: open specific sheet in excel
« Reply #1 on: February 23, 2009, 03:28:49 PM »
Try something like this:
(vlax-for sht (vlax-get objcurrworkbooks 'sheets)
  (if (= (vlax-get sht 'name) "namehere")
    (setq objsheet sht)
andrew_nao
« Reply #2 on: February 23, 2009, 03:35:02 PM »
i need a little more help if you will sir.
i placed it at the bottom of the lisp, didnt seem to do anything.
« Reply #3 on: February 23, 2009, 04:07:24 PM »
This works for me:
(and (setq objexcel (vlax-get-or-create-object "Excel.Application"))
     (setq objworkbooks (vlax-get-property objexcel "workbooks"))
     (setq objcurrworkbooks (vla-add objworkbooks))
       (if (= (vlax-get sht 'name) "Sheet3")
         (progn (setq objsheet sht) (vlax-invoke objsheet 'activate))
     (setq objcells (vlax-get objsheet "cells"))
     (vlax-put-property objcells 'item 3 3 "test")
chauny274
« Reply #4 on: February 24, 2009, 01:47:30 PM »
http://web2.airmail.net/terrycad/AutoLISP-Code.htm
I reccomend going there and getting "getexcel.lsp" for free. I've used for a program and it works great, just read the instructions and be sure to use the closeexcel command to close the sheet when your done.
These programs help create, read, and write to excel sheets.
