Author Topic: SSget help  (Read 4691 times)
Tortiz
SSget help
« on: June 10, 2013, 01:42:04 PM »
I want to do a selected set per tab. somthing like:
(setq test (ssget "_x"))
but the documation I have do not have a filter for a tab.
Any Ideas?
kpblc
Sorry for my English.
Re: SSget help
« Reply #2 on: June 10, 2013, 02:26:11 PM »
  1. ;;  ****     C U R R E N T   S P A C E   O N L Y      ****
  2. ;;  Limit the _X filter to current tab model space which ever is active
  3. (setq ss (ssget "x" (list (cons 0 "*POLYLINE") (cons 410 (getvar "ctab")))))
Tortiz
Re: SSget help
« Reply #3 on: June 10, 2013, 03:05:33 PM »
Thanks!!
alanjt
  • Standby for witty remark...
Re: SSget help
« Reply #4 on: June 10, 2013, 04:38:26 PM »
To account for being in a viewport:
(if (eq (getvar 'CVPORT) 1)
  (cons 410 (getvar 'CTAB))
  '(410 . "Model")
Dropbox
irneb
Re: SSget help
« Reply #5 on: June 11, 2013, 03:27:11 AM »
Now that might be a difficult one! What if the user wanted to select all objects in MS which are visible through the current tab's viewports.
alanjt
Re: SSget help
« Reply #6 on: June 11, 2013, 07:36:21 AM »
Do you mean only the objects visible within a viewport?
Dropbox
irneb
Re: SSget help
« Reply #7 on: June 12, 2013, 01:37:22 AM »
Exactly. Which means you'd need the coordinates of the VP (or cropped vectors if so), and also the layers which aren't VP-Frozen.
roy_043
  • BricsCAD 18
Re: SSget help
« Reply #8 on: June 12, 2013, 03:53:09 AM »
... and also the layers which aren't VP-Frozen.
Using (ssget "_A") solves this. Plus there is no need for a ctab filter.
bruno_vdh
Re: SSget help
« Reply #9 on: June 12, 2013, 04:29:13 AM »
Hello,
To the game...
(ssget "_C" '(-1e99 -1e99) '(1e99 1e99))
irneb
Re: SSget help
« Reply #10 on: June 12, 2013, 06:54:13 AM »
To the game...
That's actually a very good idea. Thus you'd need to run the PSpace command, Zoom Extents, then run MSpace, then set CVport = 2, get that selection and increment until you don't have any more VP's, each time adding the selection for the current VP into the mix.
The only issue is it only works on normal rectangular VP's, if the object would have been visible in the VP's bounding box then it's selected - even if the VP's border hides the object. But I guess that's a bit overkill.
alanjt
Re: SSget help
« Reply #11 on: June 12, 2013, 07:50:04 AM »
Hello,
To the game...
Would you mind elaborating on this?
Dropbox
Re: SSget help
« Reply #12 on: June 12, 2013, 08:00:15 AM »
Hello,
To the game...
Using the idea that ssget graphical selection modes will only select objects currently visible on screen.
bruno_vdh
Re: SSget help
« Reply #13 on: June 12, 2013, 08:18:20 AM »
Yes, the trick has its limitations, it was for the game
I used this expression to amuse me in a code posted on the forum CADxp
http://cadxp.com/index.php?/topic/35882-modifier-temporairement-l%e2%80%99affichage-des-lignes-discontinues-en-continues/page__view__findpost__p__195201
Regards,
Re: SSget help
« Reply #14 on: June 12, 2013, 08:51:57 AM »
