Author Topic: AutoCAD 15 and the API  (Read 3422 times)
Draftek
« on: May 14, 2014, 12:05:03 PM »
I've been out of the programming world and AutoCAD for some time now. Anything new in 15 regarding user experience and API?
dgorsman
Re: AutoCAD 15 and the API
« Reply #1 on: May 14, 2014, 12:43:58 PM »
Constipation, due to less fibres.   :-D
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
« Reply #2 on: May 14, 2014, 12:56:16 PM »
it's now Gluten Free!
and can cause unexplained Priapism
Draftek
« Reply #3 on: May 14, 2014, 01:01:42 PM »
So, they finally revamped the graphics?
That's it?
BlackBox
« Reply #6 on: May 14, 2014, 02:14:08 PM »
Funny, they pay lip service to supporting the Dark Theme, however as I pointed out in my review of C3D 2015 the
Dark Theme is NOT fully implemented; even by Autodesk. (what a bunch of losers)
« Reply #7 on: May 14, 2014, 02:19:35 PM »
AutoCAD 360 won't go away quietly so the Javascript API (1) may be worth investigation in the next 12 months.
The Document Tabs looked interesting .. just need to find a rational reason to use them ... other than Ohhh shiny !
(1) Jonesy, there's a good excuse to learn JavaScript :)
Draftek
« Reply #8 on: May 14, 2014, 02:31:13 PM »
Thanks,
Some interesting features as usual but nothing earth shattering either.
I'll go back to sleep now..
Keith Brown
« Reply #9 on: May 14, 2014, 05:17:29 PM »
I was planning to use this tab to display information about the current open drawings.  Since I use AutoCAD MEP I was going to investigate to running total of fittings, pipe, duct, etc and display as a html page.  So far its just a thought and nothing on paper yet.
« Last Edit: May 14, 2014, 05:24:11 PM by Keith Brown »
BlackBox
« Reply #10 on: May 14, 2014, 06:33:59 PM »
Dent Cermak
« Reply #11 on: May 14, 2014, 06:53:10 PM »
not to mention anal seepage.........
« Reply #12 on: May 14, 2014, 08:37:28 PM »
Sorry to hear about that one Dent.
MexicanCustard
« Reply #13 on: May 15, 2014, 07:42:39 AM »
Autodesk did finally adopt .NET 4.5. So you can now use Async/Await in your plug ins.
BlackBox
« Reply #14 on: May 15, 2014, 08:44:19 AM »
For those (ah me) who may not already be adept:
Quote from: MSDN, async (C# Reference)
Use the async modifier to specify that a method, lambda expression, or anonymous method is asynchronous. If you use this modifier on a method or expression, it's referred to as an async method.
If you're new to asynchronous programming or do not understand how an async method uses the await keyword to do potentially long-running work without blocking the caller’s thread, you should read the introduction in Asynchronous Programming with Async and Await (C# and Visual Basic).
