=The Document Tabs looked interesting .. just need to find a rational reason to use them ... other than Ohhh shiny !
it's now Gluten Free!and can cause unexplained Priapism
Quote from: mjfarrell on May 14, 2014, 12:56:16 PMit's now Gluten Free!and can cause unexplained Priapismnot to mention anal seepage.........
Autodesk did finally adopt .NET 4.5. So you can now use Async/Await in your plug ins.
async (C# Reference)Use the async modifier to specify that a method, lambda expression, or anonymous method is asynchronous. If you use this modifier on a method or expression, it's referred to as an async method....If you're new to asynchronous programming or do not understand how an async method uses the await keyword to do potentially long-running work without blocking the caller’s thread, you should read the introduction in Asynchronous Programming with Async and Await (C# and Visual Basic)....
