Author Topic: Freeze all layer  (Read 6017 times)
Humbertogo
Freeze all layer
« on: April 27, 2006, 02:14:19 AM »
I try to Freeze all layer with (command "_.-LAYER" "F" "*"  it working but i get Error
Error: AutoCAD variable setting rejected: "clayer" "0"; error: An error has
occurred inside the *error* functionAutoCAD variable setting rejected: "clayer"
"0"
do know any one why this err occurred and how to fix it
FengK
Re: Freeze all layer
« Reply #1 on: April 27, 2006, 02:48:37 AM »
Humbertogo,
You can't free the current layer.  Here is a quick fix:
(vl-catch-all-apply
  (function (lambda ()
         (command "-LAYER" "F" "*" "")
- KF
Humbertogo
« Reply #2 on: April 27, 2006, 03:17:59 AM »
I have use your code but i still have the err
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: April 27, 2006, 04:02:54 AM »
(defun unfrozen ()
  (vlax-map-collection
    (vla-get-layers
      (vla-get-activedocument
(vlax-get-acad-object)
      ) ;_  vla-get-activedocument
    ) ;_  vla-get-layers
    (function
      (lambda (x)
(vl-catch-all-apply
  (function vla-put-freeze)
  (list x :vlax-false)
) ;_  vl-catch-all-apply
      ) ;_  lambda
    ) ;_  function
  ) ;_  vlax-map-collection
  (vla-regen
    1
  ) ;_  vla-regen
  (princ "\nLayers are unfrozen ")
) ;_  defun
(defun frozen ()
    (vla-get-layers
    ) ;_  vla-get-layers
    (function
      (lambda (x)
(vl-catch-all-apply
  (list x :vlax-true)
      ) ;_  lambda
    ) ;_  function
  (vla-regen
    1
  ) ;_  vla-regen
  (princ "\nLayers are frozen ")
) ;_  defun
(unfrozen)
(frozen)
Jürg Menzi
  • Oberegg, Switzerland
« Reply #4 on: April 27, 2006, 04:36:20 AM »
This should do the stuff (you may need to call vl-load-com to initialize ActiveX support):
; == Function MePutAllLayers
; Controls Freeze, LayerOn, Lock, Plottable or ViewportDefault for all Layers.
; Arguments [Type]:
;   Sym = Symbol [SYM]:
;   - 'vla-put-Freeze
;   - 'vla-put-LayerOn
;   - 'vla-put-Lock
;   - 'vla-put-Plottable
;   - 'vla-put-ViewportDefault
;   Mde = Mode [BOOLEAN]:
;   - :vlax-true
;   - :vlax-false
; Return [Type]:
;   > Null
; Notes:
;   - Some symbols require a vla-regen to make the changes visible.
(defun MePutAllLayers (Sym Mde / AcaDoc)
 (setq AcaDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
 (vlax-for Obj (vla-get-Layers AcaDoc)
  (vl-catch-all-error-p
   (vl-catch-all-apply Sym (list Obj Mde))
Use:
(MePutAllLayers 'vla-put-Freeze :vlax-true)
Edited: Notes added
« Last Edit: April 27, 2006, 04:40:47 AM by Jürg Menzi »
MENZI ENGINEERING GmbH
Humbertogo
« Reply #5 on: April 27, 2006, 06:08:31 AM »
Sdoman
« Reply #6 on: April 27, 2006, 07:48:13 AM »
"0"
My guess is that the *error* function is crashing because it is trying to set the CLAYER variable to a layer that is frozen.
At the start of your routine, i suggest saving the CLAYER name and all layer states before modifying.  Then in the *error* function, i would restore the layer states and then the CLAYER variable, in that order.
CADaver
« Reply #7 on: April 27, 2006, 09:16:07 AM »
Gotta go with Steve on this one.  Humbertogo, can you post the whole code you're using??
« Reply #8 on: April 27, 2006, 10:45:38 AM »
Edit: Modified to remove poor coding precident --
(defun foo ( / clayer )
    (setq clayer (getvar "clayer"))
        (vlax-get
            (vlax-get
               'ActiveDocument
           'Layers
       '(lambda ( layer )
            (if (/= clayer (vlax-get layer 'Name))
                (vlax-put layer 'Freeze :vlax-true)
« Last Edit: April 27, 2006, 01:39:07 PM by MP »
« Reply #9 on: April 27, 2006, 11:08:46 AM »
Perhaps:
(defun freeze_all (/ doc lays clay lay)
  (setq doc  (vla-get-activedocument (vlax-get-acad-object))
lays (vla-get-layers doc)
clay (vla-get-name (vla-get-activelayer doc))
  (vlax-for lay lays
    (if (/= (vla-get-name lay) clay)
      (vla-put-freeze lay :vlax-true)
CADaver
« Reply #10 on: April 27, 2006, 01:13:25 PM »
you guys are just giving away the fish market now.  What happened to "teach 'em (me) how to fish"???
« Reply #11 on: April 27, 2006, 01:29:41 PM »
Ron,
If you look at Jürg function it is similar to yours but he uses the catch-all to prevent the error.
Where you test each layer. This is his code modified for freeze only.
(defun meFreezeAllLayers (/ acadoc)
  (setq acadoc (vla-get-activedocument (vlax-get-acad-object)))
  (vlax-for obj (vla-get-layers acadoc)
      (vl-catch-all-apply 'vla-put-freeze (list obj :vlax-true))
Not sure if the local var is needed. If not then this.
(defun meFreezeAllLayers ()
  (vlax-for obj (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
So it's a very useful function for changing layer states.
Thanks  Jürg
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #12 on: April 27, 2006, 01:34:49 PM »
It young fish,  it is necessary bring up :-)
« Reply #13 on: April 27, 2006, 01:59:43 PM »
Interesting CAB....would it be better to wite the function with less variables like this?
(defun freeze_all (/ lay)
  (vlax-for lay (vla-get-layers
    (vla-get-name
« Reply #14 on: April 27, 2006, 02:46:49 PM »
    (vla-get-name
Hi Ron, if you don't mind me cutting in --
In my opinion it would be better if you captured the name of the current layer to a variable before entering the layer iteration code. That is, you pay an unneccessary performance penalty to retrieve it on every iteration.
While I probably would favour getvar over the activex equivalent, I coded the following per your example --
(defun freeze_all ( / clayer document )
    (setq clayer
        (vla-get-name
                (setq document
    (vlax-for layer (vla-get-layers document)
        (if (/= clayer (vla-get-name layer))
            (vla-put-freeze layer :vlax-true)
Cheers.
« Reply #15 on: April 27, 2006, 03:01:44 PM »
Thanks for the input MP. Why do you prefer the getvar over activex?
This stuff is finally starting to get fun for me :).
Ron
« Reply #16 on: April 27, 2006, 03:02:33 PM »
1.Thanks for the input MP.
2.Why do you prefer the getvar over activex?
3.This stuff is finally starting to get fun for me :).
Ron
1. My pleasure.
2. The brevity.
3. Most excellent!
Sdoman
« Reply #17 on: April 27, 2006, 08:50:09 PM »
Thanks CADaver.  The way I/we interpreted the Op's question is that his original code works (he says so).  The problem he is having is with the *error* function.  I assume that the Op's code is part of a routine which crashes when the user cancels or the routine ends.
The other view, is that the Op's code does not work and is causing the *error* function to execute.  And thus appears to be an error in the *error* function, but this error should be capture while freezing the layers and therefore avoiding the error in the *error*. Whew..
Anyhow, it interesting to see so many ways to "skin a cat".  I just not sure what cat we should be skinning...  :-)
Jürg Menzi
« Reply #18 on: April 28, 2006, 03:10:58 AM »
There is no need for a lokal var.
In my apps the acaddoc object is global, therefore I've to copy this line to the extracted samples... ;-)
CADaver
« Reply #19 on: April 28, 2006, 08:18:38 AM »
That's why I'd like to see the original code.  I've beat myself silly for hourss over something as simple as misspelling the word command.
