Author Topic: Displaying full decimal answer  (Read 2141 times)
Hangman
« on: April 26, 2006, 12:41:00 PM »
Alright, this is a dumb question, but I'm feeling dumb today.
For the life of me, I can't remember how to set the display to show the full decimal answer.
I'm trying to get the answer to the following
(/ 20060425 16.0)
But this is what I'm getting.
1.25378e+006
When I'm suppose to be getting
1253776.625
How can I get the correct answer (the last entry shown) ??
Hangman  8)
Re: Displaying full decimal answer
« Reply #1 on: April 26, 2006, 12:44:59 PM »
(rtos (/ 20060425 16.0) 2 16)
Andrea
« Reply #2 on: April 26, 2006, 01:41:31 PM »
but...
RTOS = Converts a number into a string
Keep smile...
« Reply #3 on: April 26, 2006, 02:04:09 PM »
For what purpose are you trying to display it?
If it is merely for calculations, the answer returned IS correct, it is just shown in a different format.
If it is to display in the drawing editor or in Text/Mtext object then Tim's solution is what you need.
Didge
« Reply #4 on: April 28, 2006, 11:32:24 AM »
It's also worth mentioning that the system variable "DimZin" has a bearing upon the returned RTOS format.
Think Slow......
