Author Topic: lofting?  (Read 11275 times)
kpo101
lofting?
« on: January 27, 2011, 04:23:27 PM »
upon hitting the loft key the command line reads: select cross sections in lofting order: when i start at the bottom after hitting the first circle and go to the next higher circle the first circle goes out and highlights the top one, any ideas?
JCTER
Re: lofting?
« Reply #1 on: January 27, 2011, 04:28:40 PM »
I'm not following what you're saying.
Pics?
Re: lofting?
« Reply #2 on: January 27, 2011, 04:40:11 PM »
just finish picking them in the right order, then pick your path or guide curves...and see what you get
kpo101
Re: lofting?
« Reply #3 on: January 27, 2011, 04:42:35 PM »
take a 1' circle at 00 elev. and a 10" circle at +6" elev. and a 6" circle at +1' elev.. To loft this i have to start with either the bottom or the top circle and give it the lofting order. when i start with the bottom circle and click on it, it is highlighted but when i go to the next one in the order, i click on it and it highlights but the first one goes out.  I'm wondering why the first one goes out. And if i click on the third one the middle one goes out, and so on. just wondering if i made it easier to follow?
Re: lofting?
« Reply #4 on: January 27, 2011, 04:46:50 PM »
Most importantly WHAT does your command line say to you?
Command:
Command:  LOFT
Current wire frame density:  ISOLINES=4, Closed profiles creation mode = Surface
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1
found
found, 2 total
found, 3 total
Then keep picking...finish the command, and show us what you got.
JCTER
Re: lofting?
« Reply #5 on: January 27, 2011, 04:48:31 PM »
What do you mean "goes out" ?
It might be just how the routine runs.  Do my next most commonly offered answer to questions around the office "Keep going and let's see what happens!"
kpo101
Re: lofting?
« Reply #6 on: January 27, 2011, 04:52:53 PM »
After selecting loft
command: _LOFT
Select cross sections in lofting order:
kpo101
Re: lofting?
« Reply #7 on: January 27, 2011, 04:55:18 PM »
what i mean "goes out"  when i hit the first circle it turns to a dashed circle and after i hit the next circle it goes to a dashed circle and the first circle goes back solid
JCTER
Re: lofting?
« Reply #8 on: January 27, 2011, 04:55:47 PM »
Don't be scared.  Keep selecting the next sections. :P
Re: lofting?
« Reply #9 on: January 27, 2011, 05:08:14 PM »
If I tell him for the FIFTH time...will he finish the command?
kpo101
Re: lofting?
« Reply #10 on: January 27, 2011, 05:11:27 PM »
it just won't let me finish it, it says that i have to select two or more items to loft.
JCTER
Re: lofting?
« Reply #11 on: January 27, 2011, 05:12:10 PM »
Ok so that rules out my first thought, that it's just a visual/graphics SNAFU.
what is "PICKADD" set to?
kpo101
Re: lofting?
« Reply #12 on: January 27, 2011, 05:16:16 PM »
i just tried to select 3 rectangles to change the color and it won't let me select but one at a time. it may be in the selection process where i'm having trouble.
JCTER
Re: lofting?
« Reply #13 on: January 27, 2011, 05:21:10 PM »
Re: lofting?
« Reply #14 on: January 27, 2011, 05:24:43 PM »
Command:
Command:  LOFT
found
found, 2 total
found, 3 total
What does your command line say?  Did you pick TWO valid objects to loft along your selected path?
