Michael,
I have not had a chance to play with it yet this morning. I see that you are using 2009, we are still using 2008, but I have recently installed 2009 on my computer. Maybe I need to try setting them up in 2009. (I am sure that there are new and improved features in 2009) . You could send the sample file if you would like. That may give me something to compare to when setting my own up. Thanks again.
Kevin
I'm not sure if the unexpected crashed will out weight the 'new' features. A couple are interesting.
I'll send that file off a little later. I might try something different with the documentation.
Also I can rinse and repeat for 2008 rather handily and send in that format.
The 'trick'
Setup a Layout Tab that uses say the Default DWF.PC3
Edit the printable area (inked area limits) to be zero.
Use that Named Page setup as the Page Layout setting when you run your Group Section Plot.
