Author Topic: Set lisp to run every time a DWG is opened  (Read 8388 times)
CADaver
Re: Set lisp to run every time a DWG is opened
« Reply #15 on: August 02, 2006, 10:45:41 AM »
acad.lsp ist the file for make something when acad starts
acaddoc.lsp ist the file for make something when new document starts
ACADLSPASDOC=1
i think, both files are not only for fun
CADmium
« Reply #16 on: August 02, 2006, 03:57:52 PM »
ACADLSPASDOC=1
I know this Sysvar, but somethings i want only start when acad started and other things i want to do in each  document. if you don't have such differences , is ok with acad.lsp
I want only  tell about the both files ...
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
GDF
« Reply #17 on: August 02, 2006, 04:01:36 PM »
ACADLSPASDOC=1
This may help...
Gary
GDF
« Reply #18 on: August 02, 2006, 04:07:05 PM »
And this...
;;; Following is a list of AutoCAD, Express Tools, and user-defined files in
;;; the order they are loaded when you first start the program. Go to AutoCAD
;;; Help and search for "support file loading" (including quotes) and the
;;; top result is "Order of support file loading" which nets the following:
;;;      <File For:>       <Use By:>
;;;      acad2000.lsp    AutoCAD
;;;      acad.rx       User
;;;      acad.lsp       User
;;;      acad2000doc.lsp    AutoCAD
;;;      acetutil.fas       Express Tools
;;;      acaddoc.lsp       User
;;;      mymenu.mnc    User
;;;      mymenu.mnl    User
;;;      acad.mnc       AutoCAD
;;;      acad.mnl       AutoCAD
;;;      acetmain.mnc    Express Tools
;;;      acetmain.mnl    Express Tools
;;;      s::startup       User
;;; Note: If the user-defined function S::STARTUP is included in the acad.lsp or
;;; acaddoc.lsp file or a MNL file, the function is called when you enter a new
;;; drawing or open an existing drawing. Thus, you can include a definition of
;;; S::STARTUP in the LISP startup file to perform any setup operations. For more
;;; information about the s::startup function, refer to the Customization Guide.
Gary
David Hall
  • Automatic Duh Generator
« Reply #19 on: August 02, 2006, 04:14:24 PM »
I use the same as ronjonp's (getvar 'DWGNAME) phrase, I never really looked at dwgtitled until today.  Cool.   I'm still wondering what CmdrDuh uses, though.
Not been here at desk for a few days.  Let me go grab that code
David Hall
« Reply #20 on: August 02, 2006, 04:31:30 PM »
I use dwgname
David Hall
« Reply #21 on: August 02, 2006, 04:32:49 PM »
I never thought about using dwgtitled
David Hall
« Reply #22 on: August 02, 2006, 04:34:13 PM »
That is much easier to check than my method.  I was striping off the first 7 characters and matching it against "Drawing", and going from there. 0 and 1 is much easier to use.
Andrea
« Reply #23 on: August 03, 2006, 05:10:13 PM »
Thanks....this confirm that I've done the right thing.    ^-^
Keep smile...
