CAD Forums => Vertically Challenged => Land Lubber / Geographically Positioned => Topic started by: Mark on November 30, 2012, 02:18:57 PM
Thought this was odd. Got this dwg from someone else.
In created by it doesn't say 'The Doctor' does it?
Negative ....
Auditing Entities Pass 1
Pass 1 20200 objects auditedAeccDbRootSettingsNode(3FEB2) was not repaired.
Pass 1 22500 objects audited
Auditing Entities Pass 2
Pass 2 20200 objects auditedAeccDbRootSettingsNode(3FEB2) was not repaired.
Pass 2 22500 objects audited
Auditing Blocks
109 Blocks audited
Auditing AcDsRecords
Total errors found 2 fixed 0
Erased 0 objects
Fixing those errors didn't change anything. :(
I've seen this before, but can't remember when. I think it has something to do with AEC objects. The message of Civil3D doesn't mean there is Civil3D 2014 yet, but just a general message that it can't read the AEC objects. It might be a drawing from MEP, Revit, or something else that contains other object types, for which you don't have an object enabler for.
