Author Topic: Entmake Functions  (Read 14731 times)
Entmake Functions
« on: February 12, 2010, 01:22:20 PM »
I got a bit of inspiration from this, and I thought I'd write a bunch of functions that use the minimum requirements to generate an entity, mainly for those who want to quickly produce an entity, without having to look up which codes are needed, and which aren't.
Of course, the list is a working progress, but this is what I have so far:
(defun 3DFace (p1 p2 p3 p4)
  (entmakex (list (cons 0 "3DFACE")
                  (cons 10 p1)
                  (cons 11 p2)
                  (cons 12 p3)
                  (cons 13 p4))))
(defun Arc (cen rad sAng eAng)
  (entmakex (list (cons 0 "ARC")
                  (cons 10  cen)
                  (cons 40  rad)
                  (cons 50 sAng)
                  (cons 51 eAng))))
(defun AttDef (tag prmpt def pt hgt flag)
  (entmakex (list (cons 0 "ATTDEF")
                  (cons 10   pt)
                  (cons 40  hgt)
                  (cons 1   def)
                  (cons 3 prmpt)
                  (cons 2   tag)
                  (cons 70 flag))))
(defun Circle (cen rad)
  (entmakex (list (cons 0 "CIRCLE")
                  (cons 10 cen)
                  (cons 40 rad))))
(defun Ellipse (cen maj ratio)
  (entmakex (list (cons 0 "ELLIPSE")
                  (cons 100 "AcDbEntity")
                  (cons 100 "AcDbEllipse")
                  (cons 10 cen)
                  (cons 11 maj)
                  (cons 40 ratio)
                  (cons 41 0)
                  (cons 42 (* 2 pi)))))
(defun Insert (pt Nme)
  (entmakex (list (cons 0 "INSERT")
                  (cons 2 Nme)
                  (cons 10 pt))))
(defun Line (p1 p2)
  (entmakex (list (cons 0 "LINE")
                  (cons 10 p1)
                  (cons 11 p2))))
(defun LWPoly (lst cls)
  (entmakex (append (list (cons 0 "LWPOLYLINE")
                          (cons 100 "AcDbPolyline")
                          (cons 90 (length lst))
                          (cons 70 cls))
                    (mapcar (function (lambda (p) (cons 10 p))) lst))))
(defun M-Text (pt str)
  (entmakex (list (cons 0 "MTEXT")
                  (cons 100 "AcDbMText")
                  (cons 10 pt)
                  (cons 1 str))))
(defun Point (pt)
  (entmakex (list (cons 0 "POINT")
                  (cons 10 pt))))
(defun Polyline (lst)
  (entmakex (list (cons 0 "POLYLINE")
                  (cons 10 '(0 0 0))))
  (mapcar
                (entmake (list (cons 0 "VERTEX") (cons 10 p))))) lst)
  (entmakex (list (cons 0 "SEQEND"))))
(defun Solid (p1 p2 p3 p4)
  (entmakex (list (cons 0 "SOLID")
                  (cons 10 p1)
                  (cons 11 p2)
                  (cons 12 p3)
                  (cons 13 p4))))
(defun Text (pt hgt str)
  (entmakex (list (cons 0 "TEXT")
                  (cons 10  pt)
                  (cons 40 hgt)
                  (cons 1  str))))
(defun Trce (p1 p2 p3 p4)
  (entmakex (list (cons 0 "TRACE")
                  (cons 10 p1)
                  (cons 11 p2)
                  (cons 12 p3)
                  (cons 13 p4))))
(defun xLine (pt vec)
  (entmakex (list (cons 0 "XLINE")
                  (cons 100 "AcDbXline")
                  (cons 10 pt)
                  (cons 11 vec))))
(defun Layer (Nme)
  (entmake (list (cons 0 "LAYER")
                 (cons 100 "AcDbSymbolTableRecord")
                 (cons 100 "AcDbLayerTableRecord")
                 (cons 2 Nme)
                 (cons 70 0))))
(defun Layer (Nme Col Ltyp LWgt Plt)
                 (cons 2  Nme)
                 (cons 70 0)
                 (cons 62 Col)
                 (cons 6 Ltyp)
                 (cons 290 Plt)
                 (cons 370 LWgt))))
« Last Edit: February 13, 2010, 01:16:07 PM by Lee Mac »
Re: Entmake Functions
« Reply #1 on: February 12, 2010, 01:26:38 PM »
Maybe this will help you also.
[ http://www.theswamp.org/index.php?topic=17445.0 ]
« Reply #2 on: February 12, 2010, 01:29:05 PM »
Wow - I see great minds think alike Tim  :wink:
« Reply #3 on: February 12, 2010, 01:33:37 PM »
Yea.  I think entmake is faster on some items, and sometimes you just need to use entmake, so I wanted to know what was the minimum dxf codes.  Forget if it states it in that thread, but you have to watch out for the order of the dxf codes in later versions.  When I moved to '09 I had to change some of my codes that used entmake to comply with the order listed with entget.
« Reply #4 on: February 12, 2010, 01:36:48 PM »
Yeah, I've noticed that with a few objects - can't remember exactly which - but I remember having to nose around with entget to get it right.
« Reply #5 on: February 12, 2010, 02:25:16 PM »
VovKa
  • Ukraine
« Reply #6 on: February 12, 2010, 02:28:25 PM »
kinda more flexible :)
(defun Circle (cen rad ext)
  (entmakex (append (list (cons 0 "CIRCLE") (cons 10 cen) (cons 40 rad)) ext))
;;;(Circle '(0 0) 10 nil)
;;;(Circle '(0 0) 10 '((62 . 5) (8 . "TEST")))
« Reply #7 on: February 12, 2010, 02:30:13 PM »
Nice idea VovKa!  :-)
« Reply #8 on: February 12, 2010, 02:31:44 PM »
Here is a file I have been adding to over the years. The original parts was not my work.
« Reply #9 on: February 12, 2010, 02:50:52 PM »
Nice CAB,
I recognise a bit of that from David Bethel  :wink: A great reference - certainly much easier than the reference that ACAD provides.
rhino
« Reply #10 on: February 19, 2010, 10:58:41 AM »
Re: the entity name.
I'm using the functions as sub functions in the main routine - how do i get the entity name once its created for reference/modifications later?
would I need to set a variable calling entlast after running each function?
« Last Edit: February 19, 2010, 11:04:40 AM by rhino »
« Reply #11 on: February 19, 2010, 11:30:00 AM »
The entmakex returns the entity name so
(setq ent (entmakex (append (list (cons 0 "CIRCLE") (cons 10 cen) (cons 40 rad)) ext)))
gets the entity name.
And
 (setq ent (Circle '(0 0) 10 '((62 . 5) (8 . "TEST"))))
rhino
« Reply #12 on: February 19, 2010, 11:33:55 AM »
got it  :ugly: thanks!
