Code Red => .NET => Topic started by: jsr on January 02, 2011, 08:26:14 AM
Hi Everybody
Just a little query, Can we use only Hard Coded values in SendStringToExecute().
Thanks.
no, variables work
string fullCmdLine = string.Format("_{0}\n", mnuItem.CommandName);
Application.DocumentManager.MdiActiveDocument.SendStringToExecute(fullCmdLine, false, false, true);
Thanks Kerry
Can we use PAUSE or something equivalent to it inside the String passed to SendStringToExecute(). I mean instead of providing hard coded coordinate values can we allow user to pick points by himself, the way we do in autolisp.
Regards.
I have no idea, never tried it :)
My initial thought was that PAUSE is a legitimate symbol so perhaps it may work. Probably worth a try.
My next thought was why not select the points or entities from .NET and pass them with the command.
My next thought was that without sufficient information as to your intent I may as well stop talking to myself and have a nice glass of wine and think about something less taxing.
I had to implement a 'pause' within a command today.
From a modeless dialog (palette) button I needed to launch the DTEXT command and wanted to avoid the user to specify size and rotation.
I use doc.SendStringToExecute because it's the only way I found to give the focus to AutoCAD window immediately: when I try the ed.GetPoint first, I have to click twice before being able to specify a point.
So, here's the way I figured it using a CommandWillStart event handler:
private void cmdDoIt_Click(object sender, EventArgs e)
using (DocumentLock docLock = _doc.LockDocument())
// register the event handler
_doc.CommandWillStart += new CommandEventHandler(PauseForPoint);
// launch the command
_doc.SendStringToExecute("_dtext ", true, false, false);
void PauseForPoint(object sender, CommandEventArgs e)
// prompt for a point
PromptPointOptions ppo = new PromptPointOptions("\nSpecify the text start point: ");
PromptPointResult ppr = ed.GetPoint(ppo);
if (ppr.Status == PromptStatus.OK)
// continue the command
Autodesk.AutoCAD.Geometry.Point3d pt = ppr.Value;
string cmd = string.Format("{0},{1},{2} ", pt.X, pt.Y, pt.Z);
_doc.SendStringToExecute(cmd, false, false, false);
else
// cancel the command (escape)
_doc.SendStringToExecute("\x1B", false, false, false);
// unregister the event handler
_doc.CommandWillStart -= PauseForPoint;
ROFLMAO! That's exactly the way I work as well ;)
