Author Topic: Need help with math formula  (Read 4272 times)
Patch61
« on: April 13, 2011, 01:06:56 PM »
I am writing a small tool that will return the linear distance between two points on a given slope. The slope will be given in rise:distance such as 4" in 12". I need to return the distance 'X' (as the crow flies) that is a given distance down (or up) the slope.
I slept through geometry at school, so can anybody help me figure out the formula?
Thanks!
Steve
Matt__W
  • I like my water diluted.
Re: Need help with math formula
« Reply #1 on: April 13, 2011, 01:13:01 PM »
And you're doing some sort of program using VBA?
Just checking because you didn't post any WIP code.
Autodesk Expert Elite
LE3
« Reply #2 on: April 13, 2011, 01:26:43 PM »
an easy way is to use the 'rule of three'
for example:
side of triangle
a = 24
b = 8
c = 24 2 + 8 2
c = 576 + 64 root
c = 25.298
then
25.298 = 24
12.0 = X
X = 12.0 x 24.0 / 25.298 = 11.384
« Reply #3 on: April 13, 2011, 01:27:44 PM »
x= 12 * Cos (atan (8/24))
~= 11.3842
dgorsman
« Reply #4 on: April 13, 2011, 01:38:42 PM »
All that stuff that the other kids kept saying "I'll never find a use for that" keeps coming up.
A right-angle triangle will have the same proportions if you scale it around one vertex.  Even though the sides are different lengths, the angles will be the same and the sides scale down (or up) to the same relative size.  Once you have one of the new lengths then the rest is just Pythagorean or trig.
Triangles are beautiful things in math.   :love:
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Patch61
« Reply #5 on: April 13, 2011, 01:56:27 PM »
Matt,
I didn't post code because I don't need help with code. I just need a formula. Can't post a 'FIP' (formula in progress) if I don't know where to start.  :wink:
Le and dgorsman,
I don't get why you are talking about triangles. I don't think I am trying to solve a triangle. I show a triangle to give clarity to my problem. The measurement that shows as 1' could be any number, unrelated to the the other numbers.  :|
Kerry,
Once again you have come through for me!  :laugh:
Thanks to all for trying to help!
LE3
« Reply #6 on: April 13, 2011, 02:14:27 PM »
Le and dgorsman,
:-o
You are solving a triangle, and want to calculate one of the sides.
« Reply #7 on: April 17, 2011, 05:27:40 PM »
Kerry,
Note that Kerry's solution directly uses right-angled triangle trigonometric identities, hopefully this small diagram clarifies things for you:
Crank
« Reply #8 on: April 17, 2011, 05:44:50 PM »
or:
Patch61
« Reply #9 on: April 20, 2011, 04:17:05 PM »
Thanks for the clarification, guys!
I guess maybe high school was a bit important!
