CAD Forums > CAD General
LIST command odd behavior
gisdude:
I looked for LI in another instance, but no go.
I attached a copy if anyone is interested. Really kind of mystifying...
dgorsman:
Try !LI and !LIST at the command line. If either has been redefined it takes precedence over any PGP shortcut.
gisdude:
So, this is REALLY weird.
I tried "!LIST" AND THIS IS WHAT I GET: "#<SUBR @0000021a92c84d48 LIST>
Seriously?!!
When I do "!LI", it just comes up "nil"
hmmm...
kdub_nz:
What happens when you try the following commmands ??
LIST
LI
LS
If LIST and LS work
and LI does not, I'd suggest that the LI command has been defined elsewhere.
The prompt you get about
--- Quote ---Highlight Selected Layers <Yes>/No:
--- End quote ---
Do you recall seeing this elsewhere ??
note
The ! prefix does not evaluate command aliases from the .PGP file.
That is why the !LI is returning nil.
gisdude:
@kdub,
LIST - works fine.
LI - "DS>Highligh Selected Layers <Yes/No:" This does not happen for other commands.
LS - "Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue. eInvalidLayer."
The LS error has a long and detailed error description. Oy vey.
I am using "aliasedit" to edit the .pgp file. I deleted "LI" and "LS", but LIST command still works. Also, LIST is not shown in the aliasedit.
Thx for any help
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
