Author Topic: Needed a Push on Stair Lisp Routine  (Read 8000 times)
pryzmm
« on: April 20, 2008, 10:18:16 AM »
hi everyone  :| ,
could anyone help me fill in some of the missing strings needed to somehow complete my idea of this lisp.
i have been assigned to edit thousand of "stair section" mainly using "stretch" and "offset" command for most of the editing.
as i can only understand very basic lisp i would appreciate if this will be done the old passion way,,,  :lol:
i attached herewith the sample stair drawing which roughly shows the things i needed to accomplished, below is the idea i had in mind;
;CODING STARTS HERE by; pryzmm '08
(prompt "\nuse ----->> command:test1 << ")
(defun c:test1 ()
(setq entity1 ("\nselect object to stretch & make the object layer current")
(setq p1 ("\nselect 1st point")
(setq p2 ("\nselect 2nd point")
(setq p3 ("\nselect 3rd point")
(setq p4 ("\nselect 4thd point")
(setvar "osmode" 0)
;direction variables
(setq d0
(strcase (getstring "\noffset direction (Right/Top/Left/Bottom): ")))
;if user pick to the right of object
((= d0 "R") ;[color=red]dont know how to go on[/color]
;if user pick on top of object
((= d0 "T") ;[color=red]dont know how to go on[/color]
;if user pick to the left of object
((= d0 "L") ;[color=red]dont know how to go on[/color]
;if user pick to the bottom of object
((= d0 "B") ;[color=red]dont know how to go on[/color]
)(princ)
;begin stretch command
(command "stretch" "cp" p1 p2 p3 p4 "" "" p1 "25" "")
;begin offset command
(command "offset" "50" entity1 d0 "")
;change osnap
(setvar "osmode" 33)
;begin while condition
(while (setq pt1 (getpoint "\n1st point"))
(setq pt2 (getpoint "\n2nd point"))
;begin line command
(command ".line" pt1 pt2 "")
(setq ent2 (entlast))
(command ".offset" "150" ent2 d0 "")
;begin erase command
(command ".erase" ent2 "")
);end while
);end
if my idea needed an overhaul by all mean pls. do so,,,
appreciate any help,,,  :-) thank you
« Last Edit: April 22, 2008, 11:10:25 AM by CAB »
Re: Needed a Push on Lisp Routine
« Reply #1 on: April 20, 2008, 12:01:13 PM »
Maybe you could just make a block of the stairs you need, delete the old stairs, insert the block and explode?
alanjt
  • Standby for witty remark...
« Reply #2 on: April 20, 2008, 07:12:20 PM »
if the stairs had to be a certain size factor, you could just draw everything at a 1:1, then figure out a scaling factor, say based on 2 picked points b/w an area on your plan set.
that picked factor set could then determine the scale needed for your created stair block and just insert you block and (entlast) explode the block. you could even easily combine into the routine to give you a chance to erase old stairs, etc. if needed.
Dropbox
pryzmm
« Reply #3 on: April 20, 2008, 07:59:16 PM »
ron -thanks i can't as the stairs has different risers requirements for every floor.
alan, if the stairs had to be a certain size factor,,,,,,,
alan-the stairs is already pre-define and as i mentioned every floor requires different risers as each stair is not all the same floor to floor height.
i have done a simple one but this requires 4 lisp (right "0 degrees"/ top "90"/ left "180" / bottom "270") see below, if i could somehow combine this into one routine and somehow the lisp evaluates the position in which user has to pick for the offset direction (right/top/left/bottom) and uses the appropriate offset presets (50mm and 150mm) as shown in my sample1.dwg
mind you after i run this lisp it worked but somehow theres a bug i could not fix,,(still a newbie of course)   :oops:
;by: pryzmm
;stretch p-line using crossing poly selection with offset.
(prompt "\nuse ----->> command:ss0 << ")
(defun c:ss0 ();(/ ENT1 P1 P2 P3 P4 PT1 PT2 PT3)
;;;get old system variable
(setq oldlayer (getvar "clayer"))
(setq oldos (getvar "osmode"))
(setq oldortho (getvar "orthomode"))
(setq p5 "@25<0")
;;;change system variable
(setvar "cmdecho" 0)
(setvar "blipmode" 0)
(setvar "osmode" 0)
(setvar "orthomode" 0)
;;;code begin here
(setq ent1 (entsel "\nSelect Object to STRETCH"))
(setq p1 (getpoint "\n1st corner"))
(setq p2 (getpoint "\n2nd corner"))
(setq p3 (getpoint "\n3rd corner"))
(setq p4 (getpoint "\n4th corner"))
(command "stretch" "cp" p1 p2 p3 p4 "" "" p1 p5)
;(command "stretch" "cp" p1 p2 p3 p4 "" "" p1 "@25<0")
(setq pt3 (getpoint "\nBegin Offset command: Side to Offset"))
(command "offset" "50" ent1 pt3 "")
(command ".offset" "150" ent2 pt3 "")
;;;restore old variables
(setvar "clayer" oldlayer)
(setvar "osmode" oldos)
(setvar "cmdecho" cmdecho)
);end while
);end
pryzmm
« Reply #4 on: April 20, 2008, 08:01:33 PM »
oops forgot to mentioned, the lisp above is only for "0" degree if the user pick to the right of the selected entity,,,i have 3 more of this with different command: call of course,,,,,very troublesome huh,,,,tell me about it,,, :)
Dinosaur
« Reply #5 on: April 20, 2008, 08:46:42 PM »
Unlikely as it sounds, in a past existence between brief electrical and structural incarnations, I did this (by hand) for a prefab stair company.  I literally maxed out my HP15C just doing the calculations needed to define a stair riser (granted, the need to convert everything to inches and fractions bloated that some).  As I recall, the top and bottom risers could be different from the rest, but had to fall within a maximum and minimum value defined by the governing building code.  Also, the landings themselves were variables to be considered.  I am wondering if this may be asking a bit much from lisp given the variables.
Adesu
« Reply #6 on: April 20, 2008, 09:38:55 PM »
Hi pryzmm,
Test this code maybe can help you
(defun c:test (/ dis dpx ipx opt p1 p2 pt1 pt2 pt3 pt4)
  (setq pt1 '(0 0 0))
  (setq pt2 '(10 0 0))
  (setq pt3 '(10 5 0))
  (setq pt4 '(0 5 0))
  (command "_pline" pt1 pt2 pt3 pt4 "c" "")
  (initget "R T L B")
  (setq opt (strcase (getkword "\noffset direction (Right/Top/Left/Bottom): ")))
  (setq dis (getdist "\nEnter distance for stretch<10>: "))
  (if (= dis nil)(setq dis 10))
    ((= opt "R")
     (setq p1 '(12 -2))
     (setq p2 '(8 7))
     (setq ipx pt2)
     (setq dpx (polar pt2 0 dis)))
    ((= opt "T")
     (setq p1 '(12 4))
     (setq p2 '(-2 7))
     (setq ipx pt3)
     (setq dpx (polar pt3 (* pi 0.5) dis)))
    ((= opt "L")
     (setq p1 '(2 -2))
     (setq p2 '(-2 7))
     (setq ipx pt4)
     (setq dpx (polar pt4 pi dis)))
    ((= opt "B")
     (setq p1 '(12 -2))
     (setq p2 '(-2 2))
     (setq ipx pt1)
     (setq dpx (polar pt1 (* pi 1.5) dis)))
    ) ; cond
  (command "_stretch" "c" p1 p2 "" ipx dpx "")
« Reply #7 on: April 20, 2008, 11:33:19 PM »
Stairs must adhere to a set of rules. So you must define the rules for the lisp to
work within. This is often the hardest part of the process.
Here is a simple lisp. Just pick the top point of the steps & then the bottom point
of the flight of steps & it will draw a pline.
Do it again to get the second flight of steps.
Note that this is a demonstration and not meant to solve your request exactly.
(defun c:stair1 (/ ELV P1 P2 PT PTS RISE RISER RISERCNT RUN TOE TREAD TREADCNT ZDIR)
  (setq p1 (getpoint "\nPick Top of stair."))
  (setq p2 (getpoint "\nPick Bottom of stair."))
  (setq run      (- (car p2) (car p1))
        rise     (- (cadr p1) (cadr p2))
        treadCnt (abs (fix (/ run 300.0)))
        tread    (/ run treadCnt)
        RiserCnt (1+ treadCnt)
        Riser    (/ rise RiserCnt)
  (if (minusp tread)
    (setq toe 25.0)
    (setq toe -25.0)
  (setq pt  p1
        Pts (list pt)
  (repeat TreadCnt
    (setq pt  (polar (polar pt (* pi 1.5) Riser) 0.0 toe)
          Pts (cons pt Pts)
          pt  (polar pt 0.0 (- tread toe))
          Pts (cons pt Pts)
        Pts (cons pt Pts)
        pt (polar pt pi toe)
        Pts (cons pt Pts)
  (setq zdir (trans '(0 0 1) 1 0 t)
        elv  (caddr (trans (car pts) 1 zdir))
  (entmakex
    (append
      (list '(0 . "LWPOLYLINE")
            '(100 . "AcDbEntity")
            '(100 . "AcDbPolyline")
            ;;(cons 8 layer)
            (cons 90 (length pts))
            (cons 70 0) ; 1 for closed 0 overwise
            (cons 38 elv)
            (cons 210 zdir)
      (mapcar '(lambda (pt) (cons 10 (trans pt 1 zdir))) pts)
pryzmm
« Reply #8 on: April 21, 2008, 01:01:24 AM »
Test this code maybe can help you,,,
hi, adesu,, i did test your code but it crashes after the user input on the offset distance,,,  :oops:
cab, this is exactly what i needed, if somehow there could be an option for the user to input the "tread" size in my case its 300mm (nosing to nosing) and another one for the nos. of riser say "22" i could then pick the 2 points for the lisp to draw it
here's the step in which we determined the nos. of steps that goes in every storey.
1. say i have a floor to floor height of 3.2meters
2. divide this with the minimum (150mm) to maximum (180mm)  riser ht. in this case the best value will be 160mm as this will give me a whole nos. figure, (most of the time this is not the case) but the min. and max is our guide.
3. from here we would determine the nos. of steps, in this case its 10 steps each flight. total = 20 steps.
perhaps, the calculation process of determining the nos. of steps could be supply by the user instead of letting the lisp do it which may be difficult to construct.
something like this.
command: teststair
("\n Provide TREAD width")  -->> 300mm
("\n Nos. of RISER required) -->> say 20
("\n pick 1st point)            -->> Floor landing (starting point)
("\n pick 2nd point)           -->> Landing
; then from here your lisp will run,,,,, is this possible ???  :|
thanks you so much guys
Adesu
« Reply #9 on: April 21, 2008, 01:25:07 AM »
Hi pryzmm,
That code not yet finnish until to stretch function, that only as sample.
« Reply #10 on: April 21, 2008, 08:23:33 AM »
If your distance from floor to floor is fixed, and the riser height is fixed (150mm < 180mm), then the user will not need to enter the number of risers as it can be calculated from the 2 points picked by dividing the maximum riser and rounding up. Then the riser height would be recalculated based on the number of risers calculated.
« Reply #11 on: April 21, 2008, 07:32:45 PM »
Here is a revised version.
;;  CAB 04.20.08
(defun c:stair2 (/ CNT DIR DN LANDING LANDLEN MAXRISERS MINRISERS
                 P1 P2 P3 PT PTS RISE RISER RISERCNT TOE TREAD ZDIR)
  (defun MakePoly (pts layer / zdir elv)
    (entmakex
      (append
              (cons 8 layer)
              (cons 38 elv)
              (cons 210 zdir)
  (setq toe 25.0)
  (setq LandLen 1105.0)
  (or *tread* (setq *tread* 300))
  (setq p3 (getpoint "\nPick Side for stair."))
  (initget 6)
    (setq tread (getint (strcat "\nEnter Tread width: <" (itoa *tread*) ">")))
     (setq *tread* tread)
     (setq tread *tread*)
  (setq rise      (- (cadr p1) (cadr p2))
        MaxRisers (fix (/ rise 160.0))
        MinRisers (fix (+ (/ rise 180.0) 0.99))
  (while
      (initget 6)
      (setq riserCnt (getint (strcat "\nEnter number of risers ["
                                     (itoa MinRisers)
                                     " to "
                                     (itoa MaxRisers)
      (if (<= MinRisers RiserCnt MaxRisers)
        nil ; exit loop
        (princ "\nOut of range, try again.")
  (setq riser (/ rise RiserCnt))
  (if (zerop (rem RiserCnt 2)) ; even number
    (setq landing (/ RiserCnt 2)) ;
    (while
        ;;  riser number from the bottom
        (setq landing (getint "\nEnter the riser # for the landing. "))
        (if (< 1 landing MaxRisers)
          nil
  (if (> (car p1) (car p3)) ; stair left
    (setq dir pi)
    (setq dir 0.0)
  ;;  Start Stair at top
  (setq pt  p1
        Pts (list pt)
        dn  (* pi 1.5) ; down direction
        cnt RiserCnt
  (repeat (1- RiserCnt)
    (if (= landing (setq cnt (1- cnt)))
        (setq pt  (polar (polar pt dn Riser) (+ dir pi) toe)
              Pts (cons pt Pts)
              pt  (polar pt dir toe)
              Pts (cons (polar pt dir LandLen) Pts)
        (makePoly pts (getvar "clayer"))
        (setq pts (list pt))
        (if (zerop dir)
          (setq dir pi)
          (setq dir 0.0)
    (setq pt  (polar (polar pt dn Riser) (+ dir pi) toe) ; riser
          Pts (cons pt Pts)
          pt  (polar pt dir (+ tread toe)) ; tread
          Pts (cons pt Pts)
  ;;  add last riser
        Pts (cons pt Pts)
        Pts (cons pt Pts)
pryzmm
« Reply #12 on: April 22, 2008, 08:33:14 AM »
cab--->>> your a genius  8-),,, your the mannn,,,thanks dude and to all who commented,,,  :mrgreen:
Andrea
« Reply #13 on: April 22, 2008, 10:38:21 AM »
(defun c:stairs (/ p2 p2e p2_Y p2_YD dist_Y
dist_YD dist_X dist_XD disT_T dist_D p1f
p1 nm p1a p1b
  (setq nm (fix (getreal "Number of step: ")))
  (setq p1 (getpoint "Point 1"))
  (simul2)
(defun simul2 ()
  (while (= (car (setq grr (grread T 4))) 5)
    (setq p2 (car (cdr grr)))
    (setq p2e p2)
    (setq p2_Y (- (nth 1 p1) (nth 1 p2)))
    (setq p2_YD (/ p2_Y (1+ nm)))
    (setq
      p2 (polar
   p2
   (angle (list 0.0 (nth 1 p2) 0.0) (list 0.0 (nth 1 p1) 0.0))
   p2_YD
    (redraw)
    (setq dist_Y (- (nth 1 p1) (nth 1 p2)))
    (setq dist_YD (abs (/ dist_Y nm)))
    (setq dist_X (- (nth 0 p1) (nth 0 p2)))
    (setq dist_XD (abs (/ dist_X nm)))
    (setq disT_T (- (distance p1 p2) 0.5))
    (setq disT_D (abs (/ disT_T nm)))
    (setq p1f p1)
    (repeat nm
      (setq p1a (polar p1f
       (angle (list 0.0 (nth 1 p1f) 0.0)
       dist_YD
      (setq p1b (polar p1f (angle p1f p2) disT_D))
      (grdraw p1f p1a 141 1)
      (grdraw p1a p1b 141 1)
      (setq p1f p1b)
  (setq p1f p1)
  (repeat nm
    (setq p1a
   (polar
     p1f
     (angle (list 0.0 (nth 1 p1f) 0.0) (list 0.0 (nth 1 p2) 0.0))
     dist_YD
    (vl-cmdf "._Pline" p1f p1a p1b "")
    (setq p1f p1b)
  (redraw)
  (vl-cmdf "._Pline" p1b p2e "")
Keep smile...
Re: Needed a Push on Stair Lisp Routine
« Reply #14 on: April 22, 2008, 11:10:56 AM »
pryzmm you're welcome.
TimSpangler
  • CAD Naked!!
« Reply #15 on: April 22, 2008, 11:27:13 AM »
Here is my contribution.  A bit more than you needed but maybe it will spark some ideas.
ACA 2015 - Windows 7 Pro
pryzmm
« Reply #16 on: April 23, 2008, 12:16:39 AM »
[quote author=CAB link=topic=22642.msg272782#msg272782 date=1208820765]
[/quote]
cab, been using your routine since the day you've ace it,,, somehow i run into some "bug" and needed your help again,,, here's what i did, since my requirements for the minimum riser is 172.0 mm and maximum riser is 177.0 i did the changes in your code as follow;
pryzmm
« Reply #17 on: April 23, 2008, 12:24:15 AM »
oops,, fat fingers press enter accidently,,, anyway to continue, i change the figure shown in your routine to such;
        MaxRisers (fix (/ rise 172.0))
        MinRisers (fix (+ (/ rise 179.0) 0.99))
the floor to floor height i was working on is 4300mm (4.3 meters) if i do the math it will give me 25 riser with 172mm
going back to the changes i made above, i save and run the lisp again, it give me the
"Out of range, try again" warning even though i press the given data shown in the prompt (25 to 24).
perhaps when you have time, you could take a look and see if theres a work around it.
note; if i change the "MaxRisers (fix (/ rise 172.0))" to 170.0 instead of 172.0 it work,,, but somehow i need to know why it did'nt work if i put in 172.0???
thank you
« Reply #18 on: April 23, 2008, 08:43:39 AM »
It's one of those weird ACAD rounding errors.
Try this:
  (setq rise      (+ (- (cadr p1) (cadr p2)) 1e-6)
pryzmm
« Reply #19 on: April 23, 2008, 10:49:58 AM »
TimSpangler-->> many thanks for your contri,,,
Try this:
cab,, done what you've recommended, somehow that did not do the trick,,,  :laugh: hmmmm, many thanks again,,, i still gonna use this on a daily basis,,, great program  8-)
« Reply #20 on: April 23, 2008, 11:00:22 AM »
Try this and if it doesn't work upload a sample DWG with the landings clearly marked for me to test.
;;  CAB 04.23.08
(defun c:stair2 (/ CNT DIR DN LANDING LANDLEN MAXRISERS MINRISERS P1 P2 P3 PT
                 PTS RISE RISER RISERCNT TOE TREAD ZDIR MaxRise MinRise MakePoly
  (setq MaxRise 178
        MinRise 172
        toe 25.0
    (entmakex
      (append
              (cons 8 layer)
              (cons 38 elv)
              (cons 210 zdir)
  (if (and
      (initget 6)
        (setq
      ;;  adjust rise as ACAD rounding error prevents (/ 4300.0 172.0) 25
            MaxRisers (fix (/ rise (float MinRise)))
            MinRisers (fix (+ (/ rise (float MaxRise)) 0.99))
      (if (= MinRisers MaxRisers)
        (setq riserCnt MinRisers)
        (while
            (initget 6)
                                           (itoa MinRisers) " to "
                                           (itoa MaxRisers) "] "
              nil ; exit loop
        (while
            (setq tmp (fix (/ MaxRisers 2.)))
            (initget 6)
            (setq landing (getint (strcat "\nEnter the riser # for the landing. <"
                                          (itoa tmp) "> ")))
            (or landing (setq landing tmp))
              nil
        (setq dir pi)
        (setq dir 0.0)
      (setq pt  p1
            Pts (list pt)
            cnt RiserCnt
                  Pts (cons pt Pts)
            (if (zerop dir)
              (setq dir pi)
              (setq dir 0.0)
                Pts (cons pt Pts)
                Pts (cons pt Pts)
      ;;  add last riser
            Pts (cons pt Pts)
            Pts (cons pt Pts)
(prompt "\nStair with Landing Loaded, Enter Stair2 to run.")
« Last Edit: April 23, 2008, 11:13:22 AM by CAB »
pryzmm
« Reply #21 on: April 25, 2008, 12:19:40 AM »
;;  CAB 04.23.08
  (setq MaxRise 178
        MinRise 172
        toe 25.0
    (entmakex
      (append
              (cons 8 layer)
              (cons 38 elv)
              (cons 210 zdir)
  (if (and
      (initget 6)
        (setq
        (while
            (initget 6)
              nil ; exit loop
        (while
            (initget 6)
                                          (itoa tmp) "> ")))
              nil
        (setq dir pi)
        (setq dir 0.0)
      (setq pt  p1
            Pts (list pt)
            cnt RiserCnt
                  Pts (cons pt Pts)
            (if (zerop dir)
              (setq dir pi)
              (setq dir 0.0)
                Pts (cons pt Pts)
                Pts (cons pt Pts)
      ;;  add last riser
            Pts (cons pt Pts)
            Pts (cons pt Pts)
cabbbb,,,, youve ace it again mannn ,,, thanks,,,,
just thought i could still push your great program,,, is there a way for this to prompt the user for its minimum/ maximum riser height then store it as the default till user change it again in the command prompt, instead of "opening the lips and amending its parameters (min. max. riser ht.)"
(setq [color=red]MaxRise 178[/color]
        [color=red]MinRise 172[/color]
        toe 25.0
,,, this would be superbbb for me, if youve have time that is,,, right now your program has been gaining popularity in my office,, thanks to you,,,
muchas gracias amigo (hope u dont mind me calling you amigo's)  :mrgreen:
« Reply #22 on: April 25, 2008, 09:07:59 AM »
Here is an example for you to use as user input of an interger.
;;  MaxRise is global var so do not declare it.
;;  remove MaxRise from the list right after the defun
(or MaxRise (setq MaxRise 178)) ; set the default for the first time through
  ((setq temp (getint (strcat "\nEnter Max Riser Range: <" (itoa MaxRise) ">")))
   (setq MaxRise temp))
If it is a real number I use this method. Can you see the three changes I made?
(or MaxRise (setq MaxRise 178.0)) ; set the default for the first time through
  ((setq temp (getdist (strcat "\nEnter Max Riser Range: <" (rtos MaxRise 2 2) ">")))
Be sure and change this:
(setq MaxRise 178
        MinRise 172
        toe 25.0
To this:
(setq toe 25.0)
And remove MaxRise from here so it isn't declaired:
                 PTS RISE RISER RISERCNT TOE TREAD ZDIR [color=red]MaxRise[/color] MinRise MakePoly
pryzmm
« Reply #23 on: April 26, 2008, 01:00:16 AM »
cab,,, awsome,,,thanks
