Author Topic: Angle Precision  (Read 2449 times)
BazzaCAD
Angle Precision
« on: July 12, 2007, 08:35:28 PM »
How do you increase the angle Precision in LSP?
I'm getting the rotation angle of an ATTRIB.
It returns: AttAng = 1.5708 (i.e. 90 Degrees)
Then I check it...
(> AttAng (* 0.5 pi))
& get T, So I know there's some rounding going on, how do I fix it ? :)
Re: Angle Precision
« Reply #1 on: July 12, 2007, 08:42:51 PM »
What you're seeing is display precision, not internal precision.
Try this --
(rtos attang 2 15)
(rtos (* 0.5 pi) 2 15)
What do you see?
Re: Angle Precision
« Reply #2 on: July 12, 2007, 08:53:47 PM »
Rather than use a decimal approximation of an angle, why not use the angle itself ...
i.e. if you need to make a 90 degree calculation, use
(setq AttAng (angtof "90"))
Then when you run this code
(= AttAng (* 0.5 pi))
The result is T
Re: Angle Precision
« Reply #3 on: July 12, 2007, 08:59:48 PM »
Keith -- isn't he retrieving the angle from an entity (an attribute) rather than setting it explicitly?
That's how I read it; maybe I'm wrong. It happens.
Re: Angle Precision
« Reply #4 on: July 12, 2007, 09:00:42 PM »
..........So I know there's some rounding going on, how do I fix it ? :)
Warm and Fuzzy
(equal expr1 expr2 [fuzz])
(equal MyAng (* PI 0.5) 1.0e-14)  ; << adjust fuzz for  requirements
BazzaCAD
Re: Angle Precision
« Reply #5 on: July 12, 2007, 10:14:53 PM »
Thx for the advice guys.
They're all really helpful.
I'll be getting the angle from an ATTRIB, then setting it if needed.
Basically the overall goal is to make them all Right Reading...
Re: Angle Precision
« Reply #6 on: July 13, 2007, 08:21:25 AM »
You are correct ...
However, either his attribite is not at 90 degrees or he has read the attribute angle from a list and approximated it in the variable.
Insert a block with an attribute at 90 degrees
Check it with this code
(=  (cdr (assoc 50 (entget (car (nentsel))))) (* pi 0.5))
It will return T, however if the attribute is not at 90 deg, it will always return nil i.e. if it is at 90.0000001 or anything other than exactly 90 degrees it will return nil.
Use of a fuzz factor in this instance, as Kerry pointed out, will resolve the issue as can be evidenced in this code. Use the same attribute, but rotate it slightly ... say 90.01 deg
(equal (cdr (assoc 50 (entget (car (nentsel))))) (* pi 0.5) 0.01 )
